Antenna on Roof
Discussion in 'Performance and Tuning' started by GenPatton, Feb 21, 2015.
  1. Feb 21, 2015 at 5:58 PM
    GenPatton
    GenPatton [OP] Member
    Paratrooper
    Columbia SC
    2009 Tacoma 4x4 V6
    I have a 2009 4x4 Double cab. It has an oval shaped "bump" on the top of the Cab near the back window. Is this a GPS antenna?? I have a whip type antenna on the right side hood/fender. If it is GPS I would like to disconnect it-----do not need to give the NSA any help.
    Thanks, Paratrooper
  2. Feb 21, 2015 at 6:05 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    You have satellite radio?
  3. Feb 21, 2015 at 7:22 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    It's for sat radio, the 09's had it standard even if you don't have the actual tuner. If you want to vp connect sat radio there's a plug in the drivers kick panel to plug into the receiver.
    Even if it was a gps antenna why would it matter? What exactly is it doing to you?
  4. Feb 22, 2015 at 12:56 PM
    GenPatton
    Paratrooper
    Columbia SC
    2009 Tacoma 4x4 V6
    As long as the GPS antenna is connected to a power source it emits a signal.
  5. Mar 14, 2015 at 6:24 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    GPS doesn't transmit ANYTHING. It is a receive-only antenna for satellites. Satellites (GPS anyway) do not receive data from the ground, they transmit data to the ground that any GPS receiver can receive and use to compute a very precise long/lat position fix.
