Antenna Removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tbones taco, Dec 27, 2011.
  1. Dec 27, 2011 at 3:48 PM
    Tbones taco
    Tbones taco [OP] Well-Known Member
    Tony
    Carrollton
    07 PreRunner ext cab
    Flowmaster 40 smittybuilt bull bar smittybuilt nerf bars hella lights crome custome grill
    OK i'm sure someone has covered this in the past but i could not find the post. I'm changing out the antenna on my 07 xcab tomorrow. any tips or tricks? The car wash didnt remove it and i forgot to do it myself..:( i bought all new parts because the easy out didnt work.:mad: this is a standard antenna.
  2. Dec 27, 2011 at 3:49 PM
    GoDeacsWFU23
    GoDeacsWFU23 Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    unscrew it........
  3. Dec 27, 2011 at 3:50 PM
    NFK
    NFK Death Technician
    Nick
    Canada, BC, Vancouver Island, Victoria
    BLACK THUNDER
    Tiers 33/11.5 tiers Mickey Thompson,Wheels Mickey T Side Bitters 17” 3” Rev Tech Lift,Added Leaf Spring,Black Projector Headlights CCFL Halo’s / HID’S Blacked out tail light Mod,Grill craft Grill Top and Bottom Hella 500 Behind Gril,FJ40 1986 Toyota Land Cruiser Emblem Front Grill K&N Air Filter,TRD Emblem Lower Grill Bottom Right,Toyota Bug & Stone Deflector Toyota Skid Plate Rhino Lined,WeatherTech Window Visors AVID Step Up Sliders,Bushwhacker Pocket Style Fender Flares Key Hole Plugs Colour Matching,Tacoma Bed MattRear,Tailgate Anti-Theft Mod ( Key Hose Clamp) Leer 100XQ Canopy,Semi De-BadgedPainted Remaining Badges (black) FA-series Short Stubby Antenna Length: 8" TRex Eyelids,Wet Okole TRD Seat Covers Charcoal And Black With Center Console And Rear Pockets With TRD Emblem logo WeatherTech Floor Mats,48 LED Blue Dome Light
    your asking how to remove your antenna?
  4. Dec 27, 2011 at 3:50 PM
    NFK
    Nick
    BLACK THUNDER
    umm unscrew it?
  5. Dec 27, 2011 at 3:53 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I think he's talking about the entire antenna assembly, including the base. Sounds like he broke it off at the carwash.
  6. Dec 27, 2011 at 3:54 PM
    Tbones taco
    Tony
    Carrollton
    ok i know how to do it. I'm asking if anyone else has done this and found any short cuts. it broken down inside so you cant un screw it. i guess everyone has the holiday blues... Toyota didnt make this an easy fix.
  7. Dec 27, 2011 at 3:57 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Figured something was amiss, since you could change spark plugs. :)
    Have you tried peeling back the plastic fender liner from inside the wheel well?
  8. Dec 27, 2011 at 3:58 PM
    Tbones taco
    Tony
    Carrollton
    Exactly! KPT sounds like you may have done this before.
  9. Dec 27, 2011 at 3:59 PM
    TexasTacoma37
    No, but I can read.
  10. Dec 27, 2011 at 4:02 PM
    la0d0g
    running for the hills
    For crawling not hauling
    lolz
  11. Dec 27, 2011 at 4:03 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ok.....its not that bad of a job.just replaced mine.couple of tricks,move inner fender well out of the way by removing those mother f#@$!*& plastic clip things.i would recomend to get a couple extra cause they break easy,there is a 10mm bolt up in there that clamps to the mask.and remove the glove box to get in behind there easier.other than that......go at it
  12. Dec 27, 2011 at 4:04 PM
    Tbones taco
    Tony
    Carrollton
    That starts tomorrow. Removing the finder splash guard is correct to get to the main mounting bracket. However you have to remove several interior pices along with the raido. from what i could find this is the only way. not a problem for me. just seeing if there ar any short cuts.
  13. Dec 27, 2011 at 4:05 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    when I was removing my fenders to put my glassworks on, the base was impossible to separate from the fender so I ended up just cutting the antenna...still havent replaced it....
  14. Dec 27, 2011 at 4:14 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    no need to remove the radio to replace just replace the antenna.just have to remove the grab handle plastic piller on the pass. side.once thats off the connection block is right there
  15. Dec 27, 2011 at 4:20 PM
    Tbones taco
    Tony
    Carrollton
    Pataco thanks. that was what i was looking for. that sounds better than what the manuel says. How about the crow nut on the top of the mount? How did you remove that? plires???
  16. Dec 27, 2011 at 4:28 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    oh...boy.now thats a whole other issue.mine was soooooo corroded that i had to drill in to it the whole way around and chisel it off.that was a mother f'er for sure.
  17. Dec 27, 2011 at 4:46 PM
    KenLyns
    Belly of the Beast
    Another reason to use touchless car washes...
  18. Dec 27, 2011 at 5:29 PM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    FWIW, After my antenna broke I had it replaced with a Metra universal mount power antenna at Best buy for about $100.00 bucks. It worked with the factory radio which does have an antenna trigger. YMMV
    Good luck
  19. Dec 27, 2011 at 5:33 PM
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    Don't bother fixing it! I did the same thing on a tree branch years ago. My philosophy is that stuff that falls off the truck probably didn't belong there in the first place. Mud flaps, bumpers... Anyhow, I installed one of these for less $ than the parts to fix the busted factory antenna. In case that link doesn't work, Google "motrocycle hidden antenna". If you are set on fixing the factory atenna & if you don't have a it will help you see what's involved.
    good luck!
  20. Dec 29, 2011 at 4:52 PM
    Tbones taco
    Tony
    Carrollton
    Thanks that might be the thing to do.
