Antenna Replacement
Discussion in 'North East' started by benjaminlmartin, Aug 9, 2017.
  1. Aug 9, 2017 at 11:43 AM
    benjaminlmartin
    benjaminlmartin [OP] Member
    Benjamin
    2014 Super White Tacoma TRD Sport
    I've seen a few threads for DIY but I'm a little worried about doing that, I tend to break plastic things and it involves a lot of removing plastic pieces! Does anyone know a good place in/around the Boston area that wouldn't charge an arm and a leg to replace?
  2. Aug 10, 2017 at 8:08 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    What are you talking about? Replacing the actual antenna whip itself? It just unscrews from the mount on the fender. Couldn't be easier.
    Unless the newer tacomas are way different or you're talking about something I've never heard of.
  3. Aug 10, 2017 at 9:12 AM
    benjaminlmartin
    Benjamin
    The entire antenna, my broke off inside the actual mount so I need to remove and replace everything.
