Antenna Suggestions?
Discussion in 'Audio & Video' started by greggroce, Mar 20, 2011.
  1. Mar 20, 2011 at 11:37 AM
    greggroce
    greggroce [OP] Member
    Greg
    Atlanta, Georgia
    2003 PreRunner V6
    Toyota Bull Bar, Westin stepbars, Line-X bedliner
    The antenna on my 03 tacoma was broken off several years ago by a tree limb. Since then I have been replacing it with aftermarket antennas from my local aut parts store. The problem with these is they are plastic and only last a few months. I thought about installing a power antenna but didn't know if there was enough room for it or if would even be a good decision. Anyone have suggestions? Thanks!
  2. Mar 21, 2011 at 3:21 AM
    YotaComa22
    YotaComa22 Well-Known Member
    Ben
    Auburn, PA
    2016 TRD SPORT
    3" ToyTec Lift kit with ultra Goliath wheels and general grabber tires for now.
    stubbyantennas.com they are great.....
  3. Mar 21, 2011 at 3:50 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
  4. Mar 21, 2011 at 7:36 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    went to their website... under FAQ's...
    Q: How is the radio reception of these antennas when comparing to OEM one?
    A: The radio reception will decrease since these antennas are shorter.
    so why again are they great?
  5. Mar 21, 2011 at 7:40 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Looks mostly. Where I live, I have not lost any reception. I also have sat, so I mostly use that anyway.
  6. Mar 21, 2011 at 7:40 AM
    PhillyTacoma
    PhillyTacoma Well-Known Member
    Philadelphia
    10 Prerunner
    Webasto Sunroof, Pioneer AVIC-z120bt in dash nav, nerf bars, XD rims
    PWNNNNNNN'd!!!!
  7. Mar 21, 2011 at 7:44 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    i don't really notice my antenna at all (and i like it that way), so there's no way i'm adding an antenna i know performs worse than the oem.
  8. Mar 21, 2011 at 7:50 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Personal preference. If thats what you like than fine.
  9. Mar 21, 2011 at 8:00 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    fuctionality. makes zero sense to me to put a worse performing antenna on my truck.
  10. Mar 21, 2011 at 8:03 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    O K. Then don't. Like I said, I don't really use my radio. I have Sat. and use that mostly or my Ipod. I like the look of a short antenna.
  11. Mar 21, 2011 at 10:30 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Autozone sells a 13 or 14" antenna (I think the brand is Raptor?) for around ten bucks. I think it's worth a try and see how the signal strength works for the owner.
    Or for near OEM signal strength, but not the height, the OEM antenna can be fixed by removing top ball, cut a few inches off, reattach ball (needs a bit of file work, soldering & paint). I did this to my truck since I have a low garage door that my antenna was hitting on entry. I cut 2 inches off, which results in a signal optimized for around 98MHz on the FM dial.
  12. Mar 21, 2011 at 10:36 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If not using antenna or using ipod, sat, cd, phone or usb then why have one at all?
  13. Mar 21, 2011 at 10:46 AM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    Without an antenna, then you will more than likely get nothing but static. Having a shorter antenna is better than having none at all.
    I have a 8 inch antenna installed, but really only listen to my iPod. But I still have the option of listing to the radio if needed.
    In the end, it all comes down to how much you use it, and personal preference.
  14. Mar 21, 2011 at 12:10 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    dammit, I keep putting this "?" thing at the end of things that didn't need answers. My bad......:D
  15. Mar 22, 2011 at 6:59 PM
    Tom Cecc
    Tom Cecc Active Member
    Florida
    PreRunner TRD
    I installed a black Metra power antenna last year. I got ridiculed a little here about it but I like it since I usually listen to the Ipod and it stays out of sight until I need it. Bad part is I had to take it apart once because it got stuck in the up position.
