antenna wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco=bamf, Mar 18, 2009.
  1. Mar 18, 2009 at 7:51 PM
    taco=bamf
    taco=bamf [OP] Well-Known Member
    i am looking for a way to wire my antenna from my toolbox to my cab. How should i do it? i need suggestions ...
  2. Mar 18, 2009 at 7:52 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    CB antenna wire?
  3. Mar 18, 2009 at 7:52 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    there should be a little rubber grommet between the bed and the cab you can run it thru
  4. Mar 18, 2009 at 7:54 PM
    taco=bamf
    yes for my cb
  5. Mar 18, 2009 at 7:54 PM
    LonghornTaco
    Minnesota
    The connector on my antenna wire was too large to go through the cab hole so I went through one of the grommets in the floor.
  6. Mar 18, 2009 at 7:56 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    how big was your connector and how big was the grommet??
    my grommet is like maybe an inch wide...and the coax terminal was definately smaller than that...i just punched a hole in the rubber...squeezed it thru and kept going
  7. Mar 18, 2009 at 7:58 PM
    LonghornTaco
    Minnesota
    I didn't measure it, but it JUST wouldn't fit in the smaller grommets. I think I remember seeing some cb antenna wire that had smaller connectors, but this is just the one I got. Also, maybe there is a difference with the grommets between the 1st and 2nd gens... Don't know...
  8. Mar 18, 2009 at 8:00 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    stop making so much sense!
  9. Mar 18, 2009 at 8:04 PM
    LonghornTaco
    Minnesota
    What can I say....... :eek:
  10. Mar 18, 2009 at 8:06 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    i went between the cab and bed, through the passenger side frame rails, through a rubber grommet under the passenger seat, under the carpet to the bottom door trim, up that trim to the kick panel, up and behind the glove box, to where my cb was located on the drivers side center console....but after it gets inside the cab, its all up to where the cb is mounted
  11. Mar 18, 2009 at 8:08 PM
    LonghornTaco
    Minnesota
    I looked at those too... Those were the ones that were just a hair too small. I guess I have some sort of mutant antenna...
  12. Mar 18, 2009 at 8:19 PM
    jhodge83
    SC
    17 XLT Sport
    well what i did was make a hole that would be snug against the outside of the wire and manhandled the connector through it. fits damn snug w/ no probs
