Low profile antennas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paul0909, Apr 6, 2015.
  1. Apr 6, 2015 at 9:04 PM
    paul0909
    paul0909 [OP] New Member
    Austin, Tx
    '06 TRD Sport 4x4
    I want to replace the antenna on my 2012 with something that has a lower profile. I've seen the 4.7" TRD antenna's on eBay and want to know if anyone has tried them? If so, any feedback or does anyone have any suggestions on a replacement?
    Thanks,
    Paul
  2. Apr 6, 2015 at 9:09 PM
    Himynameisnick
    Himynameisnick 'Murica
    Nick
    Denver, CO
    07 White DCSB Sport
    Dont waste the money on those aluminum antennas...
    I got one a lost almost half the radio stations (I mostly just listen to the radio when I'm driving).
    They have some 13'' ones that seem better, but I am not too sure about their reception quality.
  3. Apr 6, 2015 at 9:16 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I just cut my stock one down to 13". No reception loss.
    I married my tacoma likes this.
  4. Apr 6, 2015 at 9:25 PM
    Bpassmore8
    Bpassmore8 Brian13DCSB
    Brian
    Vacaville, CA
    2013 Super White TRD Sport
    Debadged, N-Fab step bars, LED cup holder lights, LED dome and map lights, TRD stickers, HID retrofit (Morimoto Mini H1 6.0, BHLM, HomerTaco ghost raptor grill, OME 885s with 90021 up front, 60091 in the rear with trim spacer
    I have . this one and like the looks of it and it fits perfectly in the base which i saw some people complain about with other ones. I don't listen to radio so it wasn't a factor but I tried the other day and I noticed a significant amount of signal loss but I am also about 30 miles from the radio station so would get a slight amount of intermittent loss with the OEM antenna
  5. Apr 10, 2015 at 5:19 PM
    paul0909
    Austin, Tx
    '06 TRD Sport 4x4
    Thanks all VERY helpful. Saved me some coin!!!
  6. Apr 10, 2015 at 6:07 PM
    TheTacoAdventurer
    TheTacoAdventurer Well-Known Member
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
  7. Apr 10, 2015 at 9:07 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    This.
    i tried atenna-x or whatever it is, and it was complete crap. if your nipping the garage door, just remove your antenna, pull the ball off, trim off a few inches, re-install the ball, few coats of paint and you will have good reception. try not to cut the wire, just the metal part, and re-wrap the wire.
  8. Apr 11, 2015 at 9:00 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I have had terrible luck with short antennas. They seem to be fine for city dweller types where all the radio signals are close and high strength. But for driving in rural areas where signals are weak they don't seem to work very well.
  9. Apr 11, 2015 at 2:12 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Factory antenna measured 32". I cut it in half, removed the ball, reinstalled it on the 16" piece and repainted the tip. Zero discernible loss of signal/reception quality. The PBS station I listen to most often, is 60 miles away.
  10. Apr 11, 2015 at 7:12 PM
    clh850
    clh850 Well-Known Member
    Cody
    PCB, Florida
    '14 TRD Sport
    I'm thinking about doing the same thing to mind and I'm curious how this looks. Do you have a pic?
  11. May 29, 2015 at 11:44 PM
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    I heard these tend to bend back at speeds above 70 or so and they don't return to their normal position over time so you're left with a bent di*k of an antenna. I went with the TRD Shorty. It looks clean and I have an XM radio script so need for FM antenna.
  12. May 30, 2015 at 12:08 AM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I picked up a ~13" at o'reiley (garage door issue). it looks just like the stock wire wrapped one and it works great. right around $16 bucks. no loss of reception. and I'm often 50-150 miles from towers.
    goblue82 likes this.
  13. May 30, 2015 at 1:03 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    I just installed this one the other day - and yeah, it kinda looks like a limp dick while driving. It mostly goes back erect after you stop or slow down, but not entirely. I'm wondering if it'll get worse over time.
    Zero reception loss though, but I'm in the city.
  14. May 30, 2015 at 1:12 AM
    goblue82
    The Dude Abides
    Southern California
    Click muh sig
    From what i've read they do get worse over time. I really wanted to pick this one up but just couldn't get over the bent issue.
  15. May 31, 2015 at 2:48 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    You need the blue antenna pill mod.
    Turdsport likes this.
  16. May 31, 2015 at 3:36 PM
    kjm19
    kjm19 Well-Known Member
    Kurt
    Vancouver BC
    2015 MGM TRD Sport Trail Teams
    Yes they bend alot in the wind. But they go back to normal. If you do however get one that doesn't, no big deal as they are only $20 anyways lol
  17. Aug 4, 2015 at 4:37 PM
    TheTacoAdventurer
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    This is mine after about 1.5 years
  18. Aug 4, 2015 at 4:40 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Jeez. Only a year and a half and its parallel to the roadway.
    :D
  19. Aug 4, 2015 at 5:20 PM
    devkurf
    devkurf Member at Large
    midwest
    I got the little TRD one from Amazon, it was only like $7 or something. It loses my local stations from where I live once I get about 20 miles away. It looks pretty cool, but I kept the old one just in case I ever get tired of the reception.
  20. Aug 26, 2015 at 11:10 AM
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
