anthony250f supercharged 4wd long travel build
Discussion in '1st Gen. Builds (1995-2004)' started by anthony250f, Jun 20, 2014.
  1. Mar 14, 2016 at 10:26 AM
    #361
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    We can replace mine too at the same time.. Lol
  2. Mar 14, 2016 at 10:36 AM
    #362
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Spring break haha
  3. Mar 14, 2016 at 10:39 AM
    #363
    anthony250f
    Anthony
    San Diego, CA
    It blew white smoke out the tail pipe and smelled sweet
  4. Mar 14, 2016 at 11:48 AM
    #364
    anthony250f
    Anthony
    San Diego, CA
    Would replace just the head gasket and the bolts? Or all the gaskets?
  5. Mar 14, 2016 at 12:07 PM
    #365
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Eh can't hurt to do the valve cover ones while your there.
  6. Mar 14, 2016 at 12:40 PM
    #366
    anthony250f
    Anthony
    San Diego, CA
    They don't leak at all...but knowing my lu k they will after lol
  7. Mar 14, 2016 at 1:36 PM
    #367
    CayucosTacoma
    2004 Double Cab 4x4
    Down lol.
    Seriously, like replacing a fuel injector o ring and getting a knockin sound after... Just my luck
  8. Mar 14, 2016 at 1:42 PM
    #368
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    When you take off the head get a straight edge put it on the head and if there's any gaps then it's warped . I recommend doing to head studs over time they stretch with the heat cycles. Once you put everything together drive about 1000 to 1500 miles and retorque the head stud for peace of mind
  9. Mar 14, 2016 at 2:24 PM
    #369
    anthony250f
    Anthony
    San Diego, CA
    im worried it cracked the head and didnt just blow the gasket...
  10. Mar 14, 2016 at 3:13 PM
    #370
    BAMFTACO
    Juan
    Kings bruh
    How much for new heads I just did one on my buddy's trooper and we got a new head came with everything except new cam.
  11. Mar 14, 2016 at 3:17 PM
    #371
    anthony250f
    Anthony
    San Diego, CA
    come do mine :) haha
  12. Mar 14, 2016 at 5:05 PM
    #372
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your heads are aluminum. If they cracked. Oil would be everywhere.
    They can warp though and will warp well before they crack.
  13. Mar 14, 2016 at 5:24 PM
    #373
    anthony250f
    Anthony
    San Diego, CA
    I just always hear about the sc causing cracked heads especially when lean.
  14. Mar 14, 2016 at 5:24 PM
    #374
    anthony250f
    Anthony
    San Diego, CA
    It cracks between the cylinders
  15. Mar 14, 2016 at 5:38 PM
    #375
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well where you running lean?
  16. Mar 14, 2016 at 5:58 PM
    #376
    anthony250f
    Anthony
    San Diego, CA
    When it happened I can't remember. But I run lean sometimes...even though I have the urd 7th. Not that lean though 12-13 max
  17. Mar 14, 2016 at 5:59 PM
    #377
    anthony250f
    Anthony
    San Diego, CA
    Engine never even got close to overheating either
  18. Mar 14, 2016 at 6:08 PM
    #378
    Blackdawg
    Monte
    Wyoming/St. Louis
    Your fine. 13 isn't that lean man. Motors are tuned to run at 14.5 usually in closed loop
  19. Mar 14, 2016 at 6:15 PM
    #379
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not necessarily, mine is aluminum and was cracked in 4 places, leaked coolant into the cylinders when it was off. Just needed a new head casting and was like new again.
  20. Mar 14, 2016 at 6:16 PM
    #380
    anthony250f
    Anthony
    San Diego, CA
    I just went and cold started my truck fist time today and zero smoke...and the exhaust smelled like exhaust...no idea what's going on or what to do lol
