anti cease compound (spark plugs)
Discussion in '1st Gen. Tacomas (1995-2004)' started by vapovick, Sep 1, 2010.
  1. Sep 1, 2010 at 6:27 AM
    vapovick
    vapovick [OP] Active Member
    1999 Toyota Tacoma 4x4
    Ok, so I'm on my 4th round of changing plugs and wires. I just changed the plugs about 3 months ago. I have NEVER used anti cease compound on the plugs, and friend advised that I should. So my question is does everyone use it? Any issues with not using it? Should I pull them out and put some on?
    Thanks.
    ./worried :(
  2. Sep 1, 2010 at 6:36 AM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    It is a good idea to use anti seize on aluminum heads. Just at dab will do it, and be careful, anti seize reduces drag on the threads. Do not over torque when using A.S.
  3. Sep 1, 2010 at 6:37 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    I use antiseaze on everything that I want to be able to take a part again, That stuff rules!! :headbang:
  4. Sep 1, 2010 at 7:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^
  5. Sep 1, 2010 at 7:17 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I recommend the copper based anti seize over the aluminum.
    They also make this in a stick form, like big chapstick
  6. Sep 1, 2010 at 7:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ben, Why the copper?
  7. Sep 1, 2010 at 7:44 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    http://ecx.images-amazon.com/images/I/610AuhCI8XS.pdf
    Better conductivity. Plus, whats the point in using aluminum to pretect steel from aluminum.
    I know they are both "filled" with various oils and greases, but I prefer to use the copper over the aluminum in this application.
  8. Sep 1, 2010 at 8:59 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Huh, that's interesting. The copper spec specifically mentions the application to plugs in aluminum heads, whereas the aluminum spec sheet does not have this additional detail (just says spark plugs).
    Also, the spec sheet for copper says it is for up to 1800F, and the aluminum type is rated 200 degrees lower (1600F). Not that I have a clue what the typical max temperature range is in my V6 heads.
    BUT, note that for the low-end temp, the aluminum is rated down to -51F, but the copper only to -30F, so maybe our friends in Minnesota and Canada should take note for when they are changing their plugs outside in a blizzard.
    All that said, I have always used the aluminum and never had a problem...but maybe when I run out, I will swich to the copper, just to be, uh, like, all anal like Ben. (Seriously, I appreciate your attention to detail!)
  9. Sep 1, 2010 at 9:08 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :rofl:
    Don't get me wrong, they both work. I just find that one is better suited for the application than the other. Plus the little chapstick thingy I have for the copper anti seize is the cat's ass.
  10. Sep 1, 2010 at 10:09 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    I want one. That stick looks like it would be excellent for avoiding accidentally getting goobers too far down the threads near the electrode, or anywhere else you don't want it. I am on a air racing team and our plane has a 3350 CI radial with 18 cylinders, 2 plugs per cylinder. I have put on a lot of C5A from a tube using my pinky finger verrrry carefully...handling big racks of plugs and climbing up and down ladders to install them provides a lot of opportunity to f* things up.
  11. Sep 1, 2010 at 11:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Conductivity doesnt bother me, as the the "ground" of the plug is the base of the plug.
  12. Sep 1, 2010 at 11:35 AM
    chmura
    chmura Well-Known Member
    I have never used anti seize compound also. Never had any problems removing them.
  13. Sep 1, 2010 at 11:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear! Let us know how much time you spend on your heads when you come accross a seized plug ;)
  14. Sep 1, 2010 at 11:43 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I like other posters apply anti seize on the plug threads and other items, that I intend to repair in the future, also apply die electric grease to the spark plug boots to.
  15. Sep 1, 2010 at 11:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I put anti-seize on EVERYTHING that'll potentially rust, or seize up over time. Including bolts & shafts (at work too).
    Prevents moisture from getting into the threads, prevents rust from forming which prevents threads from rusting together, lubricates the metals, makes it easier to take things apart the next time.
  16. Sep 1, 2010 at 11:56 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    .....and the threads
  17. Sep 1, 2010 at 5:25 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    What about with places that do rust and may need to be removed, but must also maintain a proper torque setting. For instance, the tie rod end hold down nut for adjusting alignment.
    Only reason I bring this up is because my old tie rods were so rusted that it took Firestone working on it for over an hour before they got the bolt loose enough to make the adjustment (had been soaking it daily with pb blaster for a week). The dealer gave up after about 30 min on the initial attempt. At that point I decided they were past due for changing out and put on new inner and outer tie rods, but I also dont want it to happen again.
  18. Sep 1, 2010 at 6:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not when I glob anti sieze on them.
