Anti collision system
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SKIBUDDY58, Oct 28, 2024.
  1. Oct 28, 2024 at 1:56 PM
    SKIBUDDY58
    SKIBUDDY58 [OP] New Member
    2017 Tacoma TRD Off Road, double cab long bed
    3" Toytec lift, Hooke Road bumpers
    T completely tore the wiring harness out of the right rear of my 17 Tacoma. Is there a way to bypass it so that the warning light goes away on my dash?
  2. Oct 28, 2024 at 7:24 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Repair the damage or ignore the light, there is no bypass.
    Chew and t0p_d0g like this.
  3. Oct 29, 2024 at 4:29 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    the large sensor that is in the rear bumper , is there a way you can buy a replacement module not from the toyota dealer?
  4. Oct 29, 2024 at 5:57 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I messed up mine when I bashed my right rear bumper on the trail. I didn't tear up the wiring harness but everything that the harness plugs into to include the bumper cover mounting bracket. Anyway until I replaced all the damaged stuff I just hit the button on the lower dash with the "P" which I think stands for parking assist and that turned off the warning light.
  5. Oct 29, 2024 at 10:03 AM
    SKIBUDDY58
    Thank you so much! That wasn't the fix, but it turned out even easier. Looked in the manual, ( I know, I've already surrendered my Man Card), and guess what? You can turn it off with the dedicated button. Poof! Fixed.
  6. Oct 30, 2024 at 9:29 AM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    Good - I might have guessed wrong on which button but that works so great - fixing should not be too hard once you get a new wire harness.
  7. Oct 31, 2024 at 9:30 AM
    SKIBUDDY58
    By pushing the blind spot button "OFF", all my problems went away. I'll happily live without it. Especially when Toyota dealership was asking $4,000 to put in new.
    majpooper and musicisevil like this.
  8. Oct 31, 2024 at 3:06 PM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    $4,000 - that is bat shit crazy ! I can't find it now but I have seen a youtube video of how to install a high clearance bumper that covers removing the OEM sensors and wire harnesses and replacing them for the new bumper. The harness itself can't cost all that much the dealer parts department would probably jack up the price but you could get it on-line for pretty cheap I bet and install it your self. When I broke my bumper cover bracket Toyota wanted some insane price (a couple of hundred dollars plus) I got it on line for $88 and after I got it saw it for as cheap as $44. The sensor parts were dirt cheap - less than $20.
