Anti-freeze smell thru heater
Discussion in 'New Members' started by jpitalo, Sep 16, 2013.
  1. Sep 16, 2013 at 8:02 PM
    jpitalo
    jpitalo [OP] New Member
    Murfreesboro, TN
    1998 Toyota Tacoma
    I've got a 1998 Tacoma and when I turn the heater on it smells like antifreeze and fogs up the window. I suspect it could be a leaky heater core. I don't have any apparent leaks anywhere and the AC is fine. I'm curious with this year model if it's major work to replace the heater core if that's what it is. Also, I'm curious if the leak could be somewhere other than the heater core itself . . . or is there another solution besides replacing?
    Thanks,
    Jarrod
  2. Sep 17, 2013 at 11:16 AM
    HonoluluTaco
    HonoluluTaco Well-Known Member
    Koi
    Reston Virginia
    10 TRD 4x4 OffRoad DC/SB
    2010 TRD OffRoad DC/SB, 285/70/17 KM2's, Mickey Thompson Classic Locks, Total Chaos UCA's King 2.5 RR Coilover 3" AllPro Leaf Pack, 2.0 Fox RR, Ubolt flip kit, MBRP dual cat back, URD TCAI and MAF Calibrator, TRD Sport Hood w/ scoop, E&G Classics Custom Stainless Grill, Color matched grill and door handles WeatherTech floor mats, FormulaOne Pinacle 15%+Air blue windshield Tint, RedLine hood struts, TRD 3rd Brake light Decal, Relentless Fab Hybrid 2 piece Sliders with Kick out Relentless Fab Aluminum Front bumper, Relentless steel rear bumper, Relentless Steel IFS B.A.M.F LCA Skids, w/ Rear Diff Skid ordered In my Spare room waiting to be installed sits, Wet Okoles, Illuminated 4x4 switch mod, SockMonkey Hawaii TRD OffRoad Decal, Big box of Rammat, Speakers and Custom Sub from Mr.Marv,
    Aloha and welcome Jarrod, I'm a second Gen (Generation) guy but if you post this question on the first gen area you will get a quicker response. This area is only really to introduce yourself. Good luck!
  3. Sep 17, 2013 at 11:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you checked your radiator fluid levels & over flow tank level?
    Other than looking around for leaks... I would top off both your radiator (if needed) and the overflow tank to its required level. Check the levels every day or every few days and take notice if the fluid level drops (particularly in over-flow tank). If you're loosing fluid, you obviously have a leak.....
    You could have your cooling system pressure tested.
    http://www.youtube.com/watch?v=96aQ5DD5y78
    Never did it myself and I'm not sure you could actually 'see' a leak at heater core. But...worth a try.
