Anti freeze smell?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ttttrd, Jul 27, 2015.
  1. Jul 27, 2015 at 4:22 PM
    ttttrd
    ttttrd [OP] Member
    Central Washington
    14 Tacoma Dbl Cab TRD
    WeatherTech mats, LED lights for: bed, interior & exterior, Wet Okole heated seat covers, Gentex Auto-dimming mirror, Bloodwood custom gear shift knob, AVS hood Aeroskin, Fog light mod, Bed compartment combo locks
    Ok, this is strange or maybe it's my oversensitive nose? Many times after driving my 2014 V6, I notice a faint anti-freeze smell as I walk past the front of my truck after I've park it in the garage. Long trip, short trip...doesn't matter. I've never smelled it while driving. Also, I've never seen any evidence of a leak and haven't had to add any A/F due to a low coolant level in the overflow tank. I have looked for leaks around and under the engine with a flashlight. Nothing spotted. I have noticed this since it was new and just had it serviced, but forgot to mention it to the service adviser.
    Anybody have the same issue or have any ideas??
  2. Jul 27, 2015 at 4:31 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    you could get the water pump tested - there's an easy pressure test to rule it out either way
  3. Jul 27, 2015 at 5:11 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Check the Seal on the radiator cap.
  4. Jul 27, 2015 at 5:17 PM
    zmw
    zmw Well-Known Member
    SATX
    2014 TXproBAJA
    none
    mine has the same issue - I don't lose any fluid, but I can tell where it's coming from - my super charger coolant reservoir has a miniscule leak just enough to cause the smell - over 20k miles I've noticed just a few white drops around the coolant reservoir, i stopped caring.
  5. Jul 27, 2015 at 5:51 PM
    kpla51
    kpla51 Well-Known Member
    Fort Campbell
    check pressure of radiator cap might be leaking a little had the same problem and a new cap fixed it.
  6. Jul 27, 2015 at 6:03 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Yup I've had the same symptoms on my 2009 4.0 for many years. Never a leak or coolant loss. Not the radiator cap as I always smell it coming from the driver side tank of the radiator.
  7. Jul 27, 2015 at 7:32 PM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    Normal vehicle operation should push hot coolant into the overflow reservoir as the engine heats up; perhaps that's what you smell?
    12TRDTacoma likes this.
  8. Jul 28, 2015 at 8:01 AM
    ttttrd
    ttttrd [OP] Member
    Central Washington
    Thanks guys, some good ideas posted here. I will look at these a little closer. Let you know what I find. Thanks again!
  9. Jul 28, 2015 at 8:26 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    its under warranty, drop that thing off
  10. Jul 28, 2015 at 8:32 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    My '12 Sport did this, and my new '15 OR does it. Never see any fluid, never an overheating issue in either truck.
  11. Jul 28, 2015 at 9:04 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    Great topic. I noticed coolant smell coming from my front end in my 2014. Had dealer perform pressure test and found no leaks.
  12. Jul 28, 2015 at 9:41 AM
    cmartinez95
    cmartinez95 Well-Known Member
    Houston
    2014 TSS DCab 4x4
    2.0 SAWS, 2.0 Icon Rear Shocks, 1.5" Icon AAL, USOFFROAD Winch Mount, Warn M8000S, HID Retrofit Headlights, Custom made sliders, Fab Fours rear bumper, LED Fogs, Heated Mirrors, Auto Dimming rear view with temp and compass, BAMF antenna mounts, LED Interior lighting and Undercover SE Tonnea.
    I noticed the same thing with my '14. Coolant level has not changed and the temp is always in the same range while driving. I find it odd, but will not be losing any sleep over this. If I could see evidence of a leak I would take it in.
  13. Jul 28, 2015 at 9:44 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's normal. These trucks are notoriously noisy, and smelly of coolant due to the kind that Toyota uses, usually the overflow bottle is always a bit vented to prevent excess pressure build up. That is the reason for the mild smell. Leave it be, and don't worry about it.
    Siblue likes this.
  14. Sep 9, 2015 at 4:01 PM
    RZChief90
    RZChief90 Well-Known Member
    Virginia Beach
    I notice the same exact thing with my '13 V6. Coolant level is fine, no indication of any leaks, oil is clean. Now that I know others have the same issue, I'm not worrying about it. Just a Tacoma quirk.
  15. Sep 9, 2015 at 4:48 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Mine is the same. I have 35k miles now and have noticed it for the life of the truck. Never noticed any obvious leak.
  16. Sep 9, 2015 at 5:56 PM
    Add2481TRD
    Add2481TRD Well-Known Member
    J
    Georgia,SW
    15PreRunnerTRDOR
    Bull Bar, Tonneau Cover
    Ditto on my 15 TRD OR. Noticed it not long after purchase. Very faint smell when walking past the front and no signs any where. Assumed it was from overflow tank vent?
  17. Sep 9, 2015 at 6:03 PM
    oldracer
    oldracer Well-Known Member
    I also noticed that smell, while walking past the front of my truck.
    I wasn't in the inside of the cab; so heater core was ruled out.
    Nothing leaking, and I checked everything multiple times.
    No coolant loss.
    I had to conclude it was just vapor, coming out of the overflow tank. But not actually vapor; just the smell of it.
  18. Oct 21, 2015 at 5:20 PM
    KYDeer
    KYDeer Well-Known Member
    Noticed this vary rarely on my '15, thought it was just me.
