Anti Knock sensor question. Why does it rattle under a load?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1996_2.4, Nov 17, 2024.
  1. Nov 17, 2024 at 8:36 AM
    1996_2.4
    1996_2.4 [OP] Well-Known Member
    I have a totally stock 1996 2.4 with the 5-speed. Since I've owned the car when I drive up this big hill to work in 3rd gear the engine starts to knock and rattle. Knowing this could be fatal for an old engine, I immediately back off the gas and shift into 2nd to get up the revs and the knock goes away. This also happens on level ground when I step on it from 4th to 5th.
    Is my knock sensor going out, or is this normal?
    A few details:
    I used regular gas.
    New plugs, cap & rotor, plug wires, fuel filter, air filter.
    No weight in the truck bed.
    This has been going on consistently for 7 years.
    I honestly don't know much about knock sensors. Will it still have a little rattling even if the sensor is working good? Thanks for all the help.
  2. Nov 17, 2024 at 8:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It could still have pinging if the knock sensors are good. The high gear / low rpm condition you’re talking about is similar to supercharged 3.4 trucks that will get pinging. I want to say it’s because they’re not getting enough fuel. @Speedytech7 ?
  3. Nov 17, 2024 at 11:47 AM
    1996_2.4
    Thanks. I cant even afford to get a flat tire right now, let alone replace an engine. Good to know its not thar uncommon.
  4. Nov 17, 2024 at 3:04 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    When you say "rattling" I'm wondering if you just mean what any engine will do when it's being lugged at low RPM with a manual. Is there an actual knock?
  5. Nov 17, 2024 at 5:14 PM
    1996_2.4
    Yes, it is a definite preignition knock that will ruin the engine.
  6. Nov 17, 2024 at 5:37 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Got it then yeah 5vz’s will ping regardless if they have functioning knock sensors.
    1996_2.4[OP] likes this.
