Anti-seize lubricant on spark plug threads?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJunkie8691, Oct 17, 2021.
  1. Oct 18, 2021 at 5:51 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
  2. Oct 18, 2021 at 6:09 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Always makes me:rofl:
    I work with a couple of those guys!
    I always apply a small amount of the stuff to the threads. After having a buggered up spark plug thread 30 some years ago...I just can't do spark plugs without it now. That buggered up thread ordeal was on a mid 80's 22RE engine upon removal of factory plugs.
  3. Oct 18, 2021 at 6:45 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If there was a good chance I would never work on that vehicle again I might not care enough
  4. Oct 18, 2021 at 6:48 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    FWIW, you can file the following in anecdotal experience.
    I recently had a 6 hour battle with a stubborn steel bolt in aluminum threads during a valve cover gasket replacement. On reassembly, I used NEW bolts and a dab of anti-seize.
    I restored an '81 motorcycle, many frozen parts due to steel/aluminum interface. A dab of the copper based anti-seize on reassembly.
    Many years prior, I had an ooooolllllllddddd Buick that needed work to keep it running. I discovered the miracle of anti-seize on that ride.
    Any brake work I do gets a bit of anti-seize on threads. I reduce the torque by roughly 10%. Torque specs on fasteners is not an exact science to determine the correct value. Like anything, there is a tolerance around any specification.
    wrightme43, SageHyd and Bivouac like this.
  5. Oct 18, 2021 at 6:58 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    The sheet gets everywhere. o_O
    Anyway...I've used antiseize countless time over the years on all sorts of things. Whoever ends up with my Taco many years from now is going to love me. Because everything they unbolt will come apart like butter.
    That said....in my 35 years of wrenching, I have never once used antiseize on spark plugs. I've never had a need to or an issue after the fact.
    tacotoe[QUOTED] likes this.
  6. Oct 18, 2021 at 7:08 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    Yeah, you know it comes as a little bit of surprise that some, even master technicians for a lifetime who have posted here don't use it. That one time that I did have a problem removing a plug the engine was not completely cold. That may have been why I had a problem with one out of four.?? I mean it was plenty cooled off just not cold. Regardless I put a little on there now and never had any trouble since.
    Makes me wonder how a master technician gets the engine cooled down enough to replace spark plugs? Drop your vehicle off and pick it up tomorrow?
  7. Oct 18, 2021 at 7:15 AM
    Plain Jane Taco
    USA
    Well....you know there have been millions of spark plug changes done on warm engines over the decades. Not something I'm real keen on doing. Maybe I'm just being a little paranoid about soft warm aluminum and hardened steel plugs. But I avoid it.
    A couple of years back I did a plug change on my brother in law's Sienna. At the time it was about 15 years old with 165k miles on it. Plugs had never been changed. I was a little nervous. But all 6 came out as if they had been put in yesterday.
  8. Oct 18, 2021 at 7:24 AM
    Plain Jane Taco
    USA
  9. Oct 18, 2021 at 7:26 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I always "never sneeze" everything, except the press tapered fit on front end parts,,,, I've seen in the past where the steel seems to "tear" the aluminum threads as it comes out, on some items.
  10. Oct 18, 2021 at 7:27 AM
    Knute
  11. Oct 18, 2021 at 7:31 AM
    Plain Jane Taco
    USA
    That's why I said this...
    And NGKs are all I use. So it's relevant in my case
  12. Oct 18, 2021 at 7:37 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Just to chime in here about the NGK recommendation against it; they are correct in that it alters the torque value, and that's the main reason they say not to use it.
    There's two different issues at play here, there's galvanic corrosion and there's "Joe Bob the fucking gorilla torque spec"- what NGK is worried about is you threading your spark plugs into an aluminum head and then calmly walking over to your air wrench and giving each spark plug a couple seconds of ugga dugga like this is a completely normal thing sane humans do.
    Would I trust the coating? Maybe, that's up to you to decide. Personally I would still use a dab of copper anti seize just to be safe... As long as you torque it like a sane person the worst you've done is wasted a dab of it.
    NSDON likes this.
  13. Oct 18, 2021 at 9:34 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    You know for a hundred years....everytime you pull or press something...you ALWAYS lube....
    if not your dealing with almost pure friction, instead of snugness of the fit...
    At the microscopic level you have no ideal of the quality of that alloy metal batch run at the foundry....all steels are a formula...a mix
    Case in point.....what the freak happen with all those rusty ass tocoma frames.....bad day at the steel factory....bad ore....
    Plastic is even worse....some might last years and years....and then same oem purchased later...cracks in less than year.....wtf....
    Like my brandnew oem doorhandle.....thats crunchy now few months later....
  14. Oct 18, 2021 at 9:50 AM
    O'Silver_Taco
    MD
    And to support the other side....americans way over do everything....
    just a dab will do it....and actually I think its the under side of the head of the bolt that welds its self most time, not the threads....unless there's another problem like constant water presents....this reason an easy out has half a chance....
    And for aluminum....alot you guys are way over torqueing....you guys scare me....
    mechanics love u.....they need to put their grand kids thru college....
    because when u cross that threshold its usally professional mech time......or salvage yard...
  15. Oct 18, 2021 at 9:58 AM
    #35
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I've used anti seize and torque them to spec. I've changed my spark plugs at 30K, 60K, and 90K without any issues. My truck is at 100K now.
    davidstacoma likes this.
  16. Oct 18, 2021 at 10:13 AM
    #36
    O'Silver_Taco
    MD
    I'll installed a 1000 plugs, most of them motorcycle, and have never used a torque wrench....
    I'm just always mindful of what I was wrenching into.....
    Sounds crazy but that torque wrench interferes with that feel.....need to feel that gasket right when it goes flat....
    Hardly ever use torque wrench..... but I have all the different versions of thread locks and two different anti seize......and one heck of a washer collection....and all the copper washers, even save the old ones.....never know...
    Do find out correct torque...so you know what youir shooting for....dont guess....
    Know the trouble spots.....hang out here for while.....
    Know alot of you are already have a mind set lock .......but as a scuba diver, cyclist, and rc heli pilot,,,,, I lube, anti seize, or lock everything, whether mechanical or chemical....
    Welded destroyed seized together metal ....sucks
    If you bike in the rain you already know.....
    Bottom line...dry threads generally bad ideal....unless its your kids swingset...or fender bolt.....nobody's died from a lose fender lately....
    NSDON likes this.
  17. Oct 18, 2021 at 10:23 AM
    #37
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
  18. Oct 18, 2021 at 10:26 AM
    #38
    Plain Jane Taco
    USA
    I set my wrench to 20# when I do plugs. NGK's recommended dry torque is 18#
    tacotoe likes this.
  19. Oct 18, 2021 at 10:48 AM
    #39
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Nope. NGK specifically said that it's not needed. Never had an issue.
    Plain Jane Taco and tacotoe like this.
  20. Oct 18, 2021 at 10:53 AM
    #40
    Tacoma Mike
    Southern Maine
    I paid my house off from doing head work from people using that shit on plugs…
    Best investment customers did for me…
    Thank You
