Anti-seize lubricant on spark plug threads?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaJunkie8691, Oct 17, 2021.
  1. Oct 19, 2021 at 7:24 AM
    #81
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    My favorite torque spec: tighten until loose, then back off 1/4 turn.
    Pearson and MalinoisDad like this.
  2. Oct 19, 2021 at 9:52 AM
    #82
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    And these guys are 1000% right......dont use lock, or anti seize, any lube...
    if you dont know what your doing.......
    For the thick ones....Pull immediately into a parking lot ..... and wait for rescue, its much too dangerous out there in traffic, sometimes you have to make split second decisions to survive....and sometimes have to BREAK THE LAW to accomplish it....
    seriously doubt some of you....
    Tap your wrist and repeat 'its gonna be ok'.....
    Seriously, its time to move........ next throat choking subject.....
  3. Oct 19, 2021 at 1:02 PM
    #83
    Tacoma Mike
    Southern Maine
    Fuckin brilliant
    :thumbsup:
  4. Oct 19, 2021 at 1:03 PM
    #84
    Tacoma Mike
    Southern Maine
    Or back up till you feel something then pull forward a tad.
  5. Oct 19, 2021 at 1:08 PM
    #85
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    People torque spark plugs?
    Rambo MARINE Recon likes this.
  6. Oct 19, 2021 at 1:09 PM
    #86
    OpeCity
    Long Beach, CA
    Toyota engineers know best!
    *lower ball joint design enters the chat*
    davidstacoma likes this.
  7. Oct 19, 2021 at 1:18 PM
    #87
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    This is how I used to break my Karmann Ghia axle nuts loose.
    Tacoma Mike[QUOTED] likes this.
  8. Oct 19, 2021 at 1:23 PM
    #88
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  9. Oct 19, 2021 at 1:34 PM
    #89
    AmherstAndy
    Andy
    Masshole
    In New England, this was known as the “common gear”.
    golfindia[QUOTED] likes this.
  10. Oct 19, 2021 at 1:38 PM
    #90
    golfindia
    Yes.
    pickup truck
    Faawwkin chick magnet buddy!
  11. Oct 19, 2021 at 11:54 PM
    #91
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    What's the electrolyte between the spark plug and cylinder head?
  12. Oct 20, 2021 at 3:21 AM
    #92
    O'Silver_Taco
    MD
    That is an excellent point.....galvanic action between dissimilars usually takes years or decades...
    But a catalyst - extreme heat or an electrolyte will speed up the process 1000s.....
    Reason scuba divers wash and silicone regrease all their equipment after each day of diving in salt water....
    Even the oxygen in the air becomes corrosive at 400 F......
    Same with an alkaline battery, can sit in sealed package for long time.....but put it in your remote...
    and instantly those two dissimilars start doing their thing, 12mo later the battery is coming apart....
  13. Oct 20, 2021 at 3:22 AM
    #93
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    I was reading through this and thought to myself this may be the longest post on Tacomaworld that did not mention ball joints or Bilsteins. TY @OpeCity
    OpeCity[QUOTED] likes this.
  14. Oct 20, 2021 at 3:26 AM
    #94
    O'Silver_Taco
    MD
    At least with the ball joints....you dont have to worry about rust.....
    they wont last that long........
    And as far as toyota engineers.....there're not making the decisions.....
    Its the board of directors that makes em, and thats destine to change with politics and world economics.......
    Most companies dont survive past the grand children.......they dont have the same passion as their parents....
    they'd rather be playing with their phones, or spending all day talking about the obvious...
  15. Oct 20, 2021 at 8:50 AM
    #95
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Well...the LBJ on my 03 was still good up to 206k miles. I replaced them as preventative measure but they were still tight as a mosquitos butthole when I took them off.
    I would argue at that mileage, they should be changed out regardless.
  16. Oct 20, 2021 at 8:53 AM
    #96
    AmherstAndy
    Andy
    Masshole
    You sure those weren't replaced under recall? Are you the original owner of the truck? Chances are they were indeed high mileage, but not original.
  17. Oct 20, 2021 at 8:56 AM
    #97
    Nessal
    Texas/Bay Area
    I'm not the original owner but before I bought it I asked the original owner if he had ever replaced them knowing that it's a critical item and he said he didn't even know it was a "thing". I had a set of LBJ waiting prior to even getting the truck because I was going to change them out regardless.
  18. Oct 20, 2021 at 8:58 AM
    #98
    O'Silver_Taco
    MD
    I could be wrong....but from 2000 and newer....they made a more robust design...
    changed from a slip in strut to now you have to change out whole coil tower...
    the ball joint may same, but the whole coil bucket system is more rugged....
    lucky bastards.....
    my strut cartridge's about $30 piece....super simple job,,,
    coil tower from rock auto auto $200.... not as simple....
  19. Oct 20, 2021 at 9:02 AM
    #99
    AmherstAndy
    Andy
    Masshole
    My 2003 had the LBJs replaced under recall in 2006 (dealer confirmed by VIN lookup, also have the original service invoice). When I replaced a few weeks ago, they too were tight, with clean, caramel-colored grease and a bright shiny ball beneath the intact boot. They did however start installing rubber LBJ boot protectors in 2001 or so.
    Nessal likes this.
