Anti-seize or no anti-seize
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 099, Dec 31, 2022.
  1. Dec 31, 2022 at 8:27 PM
    099 [OP] Well-Known Member
    2022 White Tacoma Double Cab SR5
    I just wanted to get opinions of using anti-seize on spark plugs and how to modify the torque specifications if it is used. Some people highly suggest it and some say no way.
  2. Dec 31, 2022 at 8:32 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I use it very sparingly on my lawn equipment and small engines but not on any modern cars or trucks.
    Speedbird likes this.
  3. Dec 31, 2022 at 8:35 PM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    IIRC Directions state not to use AS... I believe there is a similar product already installed on them... changed mine at ~70k and they came right out. Suggest stick with OEM and rest easy.
    davidstacoma and shakerhood like this.
  4. Dec 31, 2022 at 8:39 PM
    02hilux
    Planet: EARTH
    No
    Superdave1.0 likes this.
  5. Dec 31, 2022 at 8:47 PM
    MGMDesertTaco
    I used it on the last two motors I did plug swaps on LS1 and 5.3L, but I don't torque spark plugs. Hand tight and then a little more. Don't over think it.
  6. Dec 31, 2022 at 9:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    NGK and Denso says it’s not needed.
    I have always used it. and did when I changed mine. But I probably won’t any longer on ones that don’t need it.
  7. Dec 31, 2022 at 9:15 PM
    carlk
    carlk Well-Known Member
    Virginia
    2022 MGM SR 2.7 Access Cab Utility Pkg
    I used a little too much anti-seize years ago on spark plugs on one of my cars. In about a week the anti-seize migrated to the gap on one of my plugs and shorted it. Car ran like crap. I never used that stuff again.
  8. Dec 31, 2022 at 9:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Just a tiny dab, especially if the threads have any corrosion on them coming out.
  9. Dec 31, 2022 at 9:51 PM
    BottleShark
    BottleShark Well-Known Member
    TJ
    Bullard, Tx
    2018 White TRD Offroad Long Bed
    2" lift, AAL Rear, Front bumper, 12k Winch
    it is a petroleum-base lubricant and anticorrosion that is good for up to 2200°F. The oil boils off, but compound leaves nongalling oxides of nickel, copper, and zinc between the threads. So if used, needs a very thin layer. With metal plugs and aluminum heads, there is a chance of galvanic corrosion. It's not a bad idea to use.
  10. Dec 31, 2022 at 10:06 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I changed my plugs at 50K miles. Denso is what it had from the factory, so that's what I put back in. Did not use any anti-seize. Plugs came out and went back in very easy. Change your plugs when the engine is stone cold. On a V6, passenger side is easy. Driver side is pain to reach.
  11. Dec 31, 2022 at 10:13 PM
    TA2016
    Oregon
  12. Dec 31, 2022 at 10:19 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I tend to follow the FSM.
  13. Dec 31, 2022 at 10:21 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Read the plug mfg directions. For me, I use a small SMALL dab on the threads and spread it w a Qtip.
  14. Dec 31, 2022 at 10:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I use anti-seize. For new plugs, I run the plug down, then give it 1/2 turn with the ratchet handle to crush the washer. This method is indifferent to thread lubricants. If I'm installing used plugs (for troubleshooting, etc.), I go by feel.
    auskip07 likes this.
  15. Dec 31, 2022 at 10:45 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Only need Anti Seize on black oxide plugs.
    Do not use on trivalent plated plugs, that is what this plating is for. It is sacrificial.
    This trivalent plating is found on NGK/DENSO and many other chrome looking finished plugs.
  16. Dec 31, 2022 at 11:03 PM
    Starman2112
    Starman2112 Well-Known Member
    2018 SR5 AC 4X4 Blazing Blue Pearl
    No. It’s not 1975 anymore.
    davidstacoma and Speedbird like this.
  17. Dec 31, 2022 at 11:10 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    No, the plugs have an anti-seize coating on them already.
    It also affects the heat transfer to the head, which in turns causes the plug to operate at a different temperature than intended.
  18. Dec 31, 2022 at 11:35 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Seems like people put very little, otherwise it fouls the plugs. So why put it at all?
    most of us change the plugs and have no issues taking them out. So why put the grease in the first place?
    To me, it just seems like a quick buck that manufacturers or stores make by selling that stuff.
    install your plugs correctly, and you will have no issues taking them out in 30k-60k
  19. Dec 31, 2022 at 11:39 PM
    BottleShark
    TJ
    Bullard, Tx
    There is many ideas that are good and bad for why or why not to use it. I just don't think I've seen any studies that show this to be true. To make sure we are on the same page, heat range has nothing to do with the heat, or amount, of spark. It has to do with cylinder heat dissipation. The oils burn off and what is left is nickel, copper, and zinc. All of those metals are very good a heat transfer. That is why they are found in some thermal paste. If anything, it would actually make the spark plug do it's heat dissipation more efficiently, but it would be so eligible I don't think it would be readable on a thermometer.
  20. Jan 1, 2023 at 1:35 AM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Yes.
