Anti-seize or no anti-seize
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 099, Dec 31, 2022.
  1. Jan 1, 2023 at 2:34 AM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Spark plugs are torqued so, so minimally that seizing shouldn't even be an issue. There's nothing in there to start corroding the threads unless you're flooding your truck or there's leakdown into the wells creating buildup. Not to mention at this point good quality, new spark plugs are plated/coated with an anti-seize material and galvanic corrosion between incompatible metals isn't an issue like it was 30+ years ago.
    davidstacoma and Speedbird like this.
  2. Jan 1, 2023 at 3:37 AM
    BottleShark
    BottleShark Well-Known Member
    TJ
    Bullard, Tx
    2018 White TRD Offroad Long Bed
    2" lift, AAL Rear, Front bumper, 12k Winch
    :rofl::rofl:
    Ford 5.4 Triton walks in a says, “Hold my beer.”
    Skydvrr, BillyE, Lt. Dangle and 4 others like this.
  3. Jan 1, 2023 at 4:21 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
  4. Jan 1, 2023 at 4:51 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Here’s something that might interest a few. This is from NGK.
    1. Anti-seize
    NGK spark plugs feature trivalent plating. This silver or chrome-colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without lubrication or anti-seize.
    Anti-seize can act as a lubricant, altering torque values up to 20 percent, increasing the risk of spark plug thread breakage and/or metal shell stretch. Thread breakage can sometimes involve removing the cylinder head for repair. Metal shell stretch changes the heat rating of the spark plug and can result in serious engine damage caused by pre-ignition. Do not use anti-seize or lubricant on NGK spark plugs. It is completely unnecessary and can be detrimental.
    2. Corona stain
    Corona stain is a light brown or tan discoloration on the outside of the ceramic insulator above the metal shell/hex. Corona stain is created by the high voltage traveling thru the plug that attracts the dirt or oil particles surrounding the exposed ceramic insulator between the wire/coil boot and spark plug metal shell. Corona stain is completely normal and should not be mistaken for exhaust gas blow-by or a broken seal inside the spark plug.
    3. Gapping fine-wire spark plugs
    While most NGK spark plugs are pre-gapped, there are occasions when the gap requires adjustment. Care must be taken to avoid bending or breaking off the fine-wire electrodes. NGK recommends a round wire-style or pin gauge gap tool to measure the gap. If the gap must be adjusted, use a tool that only moves the ground electrode and does not pry between or against the electrodes. NGK also recommends adjusting the gap no more than +/- 0.008” from the factory preset gap.
    4. Torque
    Torque is crucial in the ability of the plug to dissipate heat and perform properly. Always follow the manufacturer recommended torque specification. An under-torqued spark plug can lead to excessive vibration and improper heat dissipation, causing spark plug and/or engine damage. Over torquing may cause any of the following: thread damage/breakage, compromised internal seals leading to gas leakage, metal shell stretch leading to poor heat dissipation and pre-ignition.
    5.“Copper spark plugs”
    “Copper spark plugs” is a term often used to describe a standard material spark plug. However, this terminology is incorrect, as standard material plugs do not have electrodes made from copper. Copper is soft with a low melting point and cannot be used for electrodes, as they would wear very quickly. A standard material spark plug uses a nickel-alloy that may include a small copper core. The copper core has nothing to do with the electrical performance of the spark plug. A copper core is used to increase heat dissipation and durability by lowering the electrode temperatures. Nearly all NGK spark plugs, including precious metal iridium and platinum plugs, have a copper core to increase the electrode durability. Special nickel alloys, platinum, and iridium electrodes, along with copper cores are all used to enhance durability – durability meaning how long a spark plug will last before it needs to be replaced.
  5. Jan 1, 2023 at 7:10 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I had 230k miles on a Ford 5.4, zero issues.
  6. Jan 1, 2023 at 7:15 AM
    Bishop84
    Bishop84 Well-Known Member
    Most were neglected or fleet but it was common. The phaser issue was much worse for long term.
    I owned a 4,6 and it was a trooper
    Skydvrr likes this.
  7. Jan 1, 2023 at 7:25 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    lol, I didn’t even use anti-seize on my plugs in 1975.
    Actual verified facts on TW. Nice lol
  8. Jan 1, 2023 at 7:31 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I do a ton of maintenance for people.
    Every single time, that a 30 minute spark plug job becomes a 4 hour job is because of
    a) no antisieze was used last time
    or
    b) some fuknuts torqued the plugs to xxftlbs
    There is absolutely zero harm in using antisieze on lawn/Marine/auto spark plug threads. There's no valid argument against it.
  9. Jan 1, 2023 at 7:31 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Anytime i deal with aluminum heads, i put some anti-sieze on the plug threads. Just don't overdue it.
    Big tall dave likes this.
  10. Jan 1, 2023 at 8:26 AM
    photogr4x4
    Canada
    TRD OR
    Nada
    I'm still happy with my little 3L Ranger but I'm sitting way lower in kilometers; about 135,000 converted. It's a pig on gas, as underpowered as can be but I'm not convinced it's going to die given how poorly the previous owner treated it and how happy it still is.
  11. Jan 1, 2023 at 8:59 AM
    davidstacoma
    David
    NC
    NGK begs to differ. Post#25.
  12. Jan 1, 2023 at 9:05 AM
    jsi
    jsi Well-Known Member
    native earthling
    ^ THIS! ^
    First don't be stupid and gob a whole bunch on the threads, a little bit will do ya. Second the torque pendants will humph and grunt but the truth is tight and a little bit more is all you need. Here's another thing that will cause the pendants to humph and grunt, use iridium plugs. Third, I put anti-seize on anything I want to come apart later, but I live where they salt the roads, ymmv. Fourth, really, don't over think it.
    Iridium plugs in a 2nd gen 6 This plug has close to 90K miles on it and was installed with anti-seize.
    MGMDesertTaco[QUOTED] likes this.
  13. Jan 1, 2023 at 9:07 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Agreed! But I will say that the armchair alarmist who hang out here certainly are entertaining.
    Bishop84 likes this.
  14. Jan 1, 2023 at 9:11 AM
    Bishop84
    The worst is the 4x4 on highway threads, people make it seem like your truck will explode.
    Anti seize doesn’t hurt shit in moderation . The horror stories are from people using it like tooth paste.
    Big tall dave, BillyE, b_r_o and 2 others like this.
  15. Jan 1, 2023 at 10:39 AM
    #35
    099
    099 [OP] Well-Known Member
    2022 White Tacoma Double Cab SR5
    Ok. Well, I guess it's 50/50. Most say yes and most say no. Thanks for everyones input. There are a lot of intersting posts. Have a great New Year and be safe.
  16. Jan 1, 2023 at 1:49 PM
    #36
    BottleShark
    TJ
    Bullard, Tx
    So your one truck that had no issues and that means that the years of repairing trucks are null and void. Fords 5.4 modular engine has to be one of the worst reliable engines ever made.
    mattleg likes this.
  17. Jan 1, 2023 at 2:01 PM
    #37
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Same situation but opposite experience. Worked on multiple car engines that had anti-seize on plugs that had baked out the carrier oil and left the threads packed full of hard gummy anti-seize filler. They came out difficult and go in difficult - ain't nobody like driving a plug in the entire length with a ratchet. (And no, not cross threaded, counter rotation to catch the thread properly, just gummed up with anti-seize.)
    Today, after the initial break free, if it doesn't thread out with fingers on the extension, they get tighten back down and I decline to go further.
    I cannot understand how it takes 4 hours without anti-seize, you just turn them with a mini breaker bar and then twist out with your fingers. What are you doing that it takes 4 hours, spending 30min with each plug sweet talking and rubbing it's tip?
  18. Jan 1, 2023 at 2:08 PM
    #38
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Agree, the 3-valve 5.4 is quite possibly the worst engine in the last 25 years. The 2-valve was ok, most people don't know the difference though.
    Bishop84 and BottleShark[QUOTED] like this.
  19. Jan 1, 2023 at 2:12 PM
    #39
    Bishop84
    We used to get them roaring hot, spray penetrating in, crack them, then let them sit over night.
    Never broke one with that method.
    Terrible design.
    mattleg[QUOTED] likes this.
  20. Jan 1, 2023 at 2:13 PM
    #40
    BottleShark
    TJ
    Bullard, Tx
    Plus all of them will have VVT and cam phaser issues.
