Anti-seize or no anti-seize
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 099, Dec 31, 2022.
  1. Jan 1, 2023 at 5:09 PM
    #61
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I used a dab when I replaced my plugs at 60k since I didn't want the next owner to create a thread here about stripping out a plug when they replace them.
    It won't matter for me since I am never replacing them again.
    Skydvrr and shakerhood like this.
  2. Jan 1, 2023 at 7:12 PM
    #62
    old.shopteacher
    old.shopteacher Active Member
    2022 Tacoma TRD Sport AC MT
    I use AS on the rear of my wheel rims. I put a light coat on the contact points where the rim meets the rotor or brake drum. The alloy wheels tend to corrode onto the iron surfaces of the hubs. A little bit does the trick.
  3. Jan 1, 2023 at 7:24 PM
    #63
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    Ditto and I torque to spec.
    old.shopteacher likes this.
  4. Jan 1, 2023 at 10:29 PM
    #64
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Well hello there then. I worked with many of you guys in civilian nuclear. Boomer or fast attack?
  5. Jan 2, 2023 at 1:12 AM
    #65
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    Those are NGK engineers, not every day mechanics. They don't need to deal with stuck plugs on a daily basis.
    I've used Anti-seize since 1970 and never had any issues using it.
    Skydvrr and davidstacoma[QUOTED] like this.
  6. Jan 2, 2023 at 1:20 AM
    #66
    Benny22
    20Tacoma
    Every anti-seize I've ever used is good to 2500*f or higher. I would guess folks were using grease. or oil, and not anti-seize.
  7. Jan 2, 2023 at 3:45 AM
    #67
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Squadron 8 fast boat in Norfolk (USS Cincinnati SSN 693). Also a teaching tour up at NPTU Ballston Spa. Good times brother!
    davidstacoma[QUOTED] likes this.
  8. Jan 2, 2023 at 4:35 AM
    #68
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    That's for the filler, typically nickel, not the carrier oil. Also note the adiabatic flame temperature of gasoline is around 3800F.
  9. Jan 2, 2023 at 10:00 AM
    #69
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    We used Milk Of Magnesia on the Combuster Plug on the GE-90, never seized or gummed up.
  10. Jan 2, 2023 at 11:00 PM
    #70
    Benny22
    20Tacoma
    Note the melting point of Aluminum is 1200*f, so whats your F-ing point. You don't have a point, Just another BS post. Folks show you some facts, you reply with more BS!
    :luvya::luvya::luvya:
  11. Jan 3, 2023 at 2:39 AM
    #71
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    As little as possible or
    Lt. Dangle and Skydvrr like this.
  12. Jan 3, 2023 at 7:27 AM
    #72
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    3.5L - 80K miles.
    Lt. Dangle and mquibble like this.
