Anti Seize !!
Discussion in 'Suspension' started by Yota_Fox, Nov 27, 2012.
  1. Nov 27, 2012 at 10:01 PM
    Yota_Fox
    Yota_Fox [OP] Active Member
    Ben
    Beaverlodge,Alberta, Canada
    08 DCLB TRD Ducks Unlimited
    Grillcraft , Piaa behind grill and fog in bumper,BHLM, Kenwood DD In Dash Nav, Garmin My Mechanic on Nuvi1495, Max 4 Duck blind seat covers, Debadged , cargo bed lights, Wilson cell booster,
    Ok so I'm 3/4s the way through my tear down and last night I busted more knuckles and cursed to get the damn front leaf bushing bolts out !!! My question is can or why couldn't I put some anti seize on the new bolt shanks to possibly avoid this in the future !?!? Or is this one of those things that the bolts are supposed to lock themselves in solid and not move ??
  2. Nov 28, 2012 at 9:37 AM
    neonlazer
    neonlazer Mechanically Goofy
    Jeffrey
    Lafayette, LA
    '12 DCSB 4x4 SR5
    I don't think there are any bolts that you can't put anti-seize on!(watch someone prove me wrong..)
  3. Nov 28, 2012 at 9:42 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    One thing to take into account with anti-seize is that it affects your torque wrench readings when tightening, due to the lesser amount of friction the nut is encountering. So sometimes using antiseize can lead to over-torquing if you are not careful.
  4. Nov 28, 2012 at 9:49 AM
    neonlazer
    Jeffrey
    Lafayette, LA
    '12 DCSB 4x4 SR5
    That is something i never thought about...TIP OF THE DAY!
  5. Nov 28, 2012 at 9:53 AM
    KPT
    09 Prerunner
  6. Nov 28, 2012 at 9:54 AM
    S.B.
    S.B. Well-Known Member
    Sean
    SD, CA Now in Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    SAW 2.0s, Wheeler's 3-leaf AAL, On Board Air, 255/85/16 Cooper Discover S/T, CBI Sliders, Built right UCAs, 6" Harbor Freight Lights (converted to HIDs), KC Slim Lights.
    In all honesty, not true. No torque spec (at least in vehicles that I've worked on) is specified for being lubed or not lubed
  7. Nov 28, 2012 at 10:03 AM
    Brunes
    Brunes abides.
    Rotorhead
    Just because it doesn't say where you looked - Doesn't make it not true. There certainly are different torque specs for lubed versus un-lubed threads.
    I would venture a guess that most torque settings assume unlubed, but I'd have to pull out the books to confirm.
  8. Nov 28, 2012 at 10:29 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Update your knowledge: http://www.imperialsupplies.com/pdf/A_FastenerTorqueCharts.pdf
    Per the chart, reduce your lubed torque by 20% for use of anti-seize, and always lubricate and use lubed torque values.
  9. Nov 28, 2012 at 10:33 AM
    scocar
    scocar Purity of essence
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Back to square one after the 2001. So...
    If we all go back and carefully read what the OP asked and focus on answering his question, he specifically mentioned shanks, not threads.
    Shanks, yes. Or grease them. I put anitseize on mine.
    Threads, no.
  10. Nov 28, 2012 at 10:53 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    What about anti-sieze on the bushings?
  11. Nov 28, 2012 at 11:37 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    The rubber or uretahne bushings in the leaf eyes? Use a light coating of grease for install. The corrosion causing seizure really only happens between the bolt shank and the metal sleeve in the bushing it goes through. Moly grease is fine.
    You can get greaseable bushings if you want (mentions moly or teflon grease)
    http://www.wheelersoffroad.com/gstacoma.htm
  12. Nov 28, 2012 at 12:32 PM
    Yota_Fox
    Ben
    Lots of info and yes I mean shanks the threads where fine just the shanks rusted solid to the middle of the sleeves on the bushing I've had the same problem on my 89 years ago and thought I'd find out if it was possible thanks alot guys
  13. Nov 28, 2012 at 12:35 PM
    Yota_Fox
    Ben
    Those wheeler greasable ones you are talking about are for 99 to 04 I've got an 08 ?
  14. Nov 28, 2012 at 1:23 PM
    thinkingman
    redmond WA
    I bought these
    Bushing Set for CS047 Spring Set:15.69/set [​IMG]
    Black graphite impregnated polyurethane bushings with sleeves. Does the shackle end of both springs. The CS047 springs come from OME with factory style main eye bushings already installed. OUR INEXPENSIVE BUSHING KIT SOLVES THE PROBLEM OF TRYING TO RE-USE YOUR FACTORY RUBBER BUSHINGS FOR THE SHACKLE END OF THE SPRING!
