Anti Seize
Discussion in 'Technical Chat' started by Buckaroo1993, Jun 16, 2018.
  1. Jun 16, 2018 at 7:04 AM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Anybody use anti seize when replacing brake bleeders?
  2. Jun 16, 2018 at 7:24 AM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Be careful, the anti-seize will let you apply much higher torque. While building some BBS wheels, I had some new bolts with out the dry thread-locker, so put the liquid thread locker on. Broke two of them using the correct torque values. Found out that I had to decrease the values by 16% from Lock-tite . I imagine that the anti-seize will lubricate the threads like the Lock-tite did.
  3. Jun 16, 2018 at 7:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    No.
    New bleeders should come with coated threads. Material that resists seizing and leaks both.
    Kinda like a teflon tape. But different. Most I've seen have been red.
  4. Jun 16, 2018 at 8:13 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    As an engineer and user I have deviled Loctite for years about a definitive number for torque reduction when using the various locking compounds. The new owners (a German WW2 bomber builder) won't commit to a set torque reduction for any of them. They always refer you to their tech sheet for the product - which says it is subject to your own testing (look it up). Total B.S. as no one short of CAT or Komatsu could afford such a thing.
  5. Jun 16, 2018 at 1:07 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I use it all the time even on new ones .
    I have yet to see any bleeders with any coating
    I have slowed down some I used to buy a case on Never Seize once a year.
    Being in the Liquid Brine belt it gets used on every thing
  6. Jun 16, 2018 at 1:41 PM
    kgw
    kgw
    SoCal
    99 PreRunner
    I'll look for the .pdf I scrounged up on the Interwebs a few years back...
  7. Jun 16, 2018 at 7:10 PM
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    The problem is, the torque reduction is going to vary based on thread type, class of fit, thread material, thread length, type and amount of product, ect.
    There's no way loctite can give an accurate number
    For threads over 3/8 I don't even bother reducing torque...for smaller screws I'll reduce it around 15% when dealing with oil, loctite, anti seize, ect
  8. Jun 16, 2018 at 7:18 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Everything I take apart with intention of keeping gets a dab.
    Here in the salt belt, it is your friend if you intend to keep the truck past the end of the warantay.
    Taco1999 and Wyoming09 like this.
  9. Jun 18, 2018 at 7:59 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Amen brother!
    koditten[QUOTED] likes this.
