Anti-Sieze...Yes or No???
Discussion in 'Technical Chat' started by Elkhound, Mar 19, 2013.
Anti-sieze... Yes or No?
Poll closed Apr 18, 2013.
  1. YES-always use anti-sieze
    52 vote(s)
    83.9%
  2. NO-follow plug manufacturers directions
    10 vote(s)
    16.1%
  1. Mar 19, 2013 at 8:03 AM
    Elkhound
    Elkhound [OP] Member
    Kurt
    New Hampshire
    Tacoma 4x4
    Greetings Tacoheads! I'm about to change my Denso Iridium plugs for the first time at 70k on my 2.7 2006 Taco. The question is whether or not to use anti-sieze? Denso has a website www.globaldenso.com/PLUG/ Just click on catalog downloads then click on Spark Plugs Training Manual 2005/2006 (English). This is a 100 page training manual. Page 61 gives notes for installing and removing Iridium plugs and there is no mention of using any anti-seize on Denso plugs. At www.ngksparkplugs.com there is a link under tech bulletins and releases on spark plugs and the use of anti-sieze. NGK recommends NOT to use anti-sieze due to a special trivalent Zinc-chromate shell plating on the threads. Both websites have you change the plugs on a COLD engine. So, what do you all think? Anti-sieze Yes or No?
    BTW I purchsed my plugs from www.RockAuto.com At $5.79 a piece. Even with shipping it beats Advance Auto at $8.99 a piece if you don't mind the wait. You can also search TW for RockAuto to get a discount code to use at checkout.
  2. Mar 19, 2013 at 8:04 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I used it. I've never heard not to use it on spark plugs though.
  3. Mar 19, 2013 at 8:23 AM
    huntdd
    huntdd Member
    Vacaville
    08 Prerunner sport SR5 AT w/tow
    I always use anti-seize on plugs. I don't see what the downside would be. Rockauto is the place I go for most of my parts.
  4. Mar 19, 2013 at 8:30 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Always! after 100,000+ miles those things can get seized up as shit! and you really dont want to to screw up a spark plug in your parking lot when you try and break it loose yourself.
  5. Mar 20, 2013 at 7:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    Some of the newer designed plugs have taken into account the issue of seizure of old spark plugs. However I have always used it on my engines. I do however make sure that I use a minimal amount, getting the threads wet, but not dripping, and am cautious to not let any get on the electrode tip, or the ceramic.
  6. Mar 20, 2013 at 7:18 AM
    medic2230
    Murph
    Bama! Roll Tide
    I've never used it personally, on my 2000 Taco or my 2011 I just did. I've never had a problem.
  7. Mar 20, 2013 at 7:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    ALWAYS!!!!
    Anti-seize is what it says - prevents seizing of two metals. It has nothing to do with the performance of the plugs because its applied to the threads and threads only. I use it on my plugs, I use it on my lug nuts. I use it on the mating surfaces between the axle hubs/rotors. I use it on just about everything that's a metal-to-metal contact surface that's exposed to moisture and can rust & seize. I use it at work on similar metal-on-metal situations.
    Not only does it prevent seizing metals, but it makes things a whole easier to take apart the next time you change your plugs (or fix it).
    And honestly - Any 'special coating' doesn't mean anything unless it has a long time history & reputation for doing what it claims. I wouldn't trust it.
  8. Mar 20, 2013 at 7:41 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    YES! Especially in an Aluminum head.
  9. Mar 20, 2013 at 9:27 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Any recommendation on what type Anti-seize to use
    for plugs??
    Thanks.
    PC
  10. Mar 20, 2013 at 9:33 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Locktite makes a very good, high nickel anti-seize that I personally use...expensive and usually available at better parts houses.
    Howard
  11. Mar 20, 2013 at 9:49 AM
    streamreeper
    streamreeper If you gonna shoot,shoot-don't talk
    matt
    the woods of western new york
    04 tacoma TRD. -2009 acess cab 4x4 green.
    2004 new frame dif breather deck plate ome 881's nitro's dakkar leafs nitro's access tanoue cover
    the only reason not to would be the possibility of overtorqeing the plugs
  12. Mar 20, 2013 at 12:48 PM
    Collins
    North Carolina
    Thank you sir.
    PC
  13. Mar 20, 2013 at 1:03 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I use it all the time, on areas exposed to high heat, like the plugs, and exhaust. But I would NOT use it on head bolts, due to it possibly affecting the applied torque.
  14. Mar 20, 2013 at 3:24 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Of course--do not leave home without it!!!
  15. Mar 20, 2013 at 3:25 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    This ^^
  16. Mar 21, 2013 at 6:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    Some people would say that was obvious, but you do make a good point by bringing attention to that. Do not EVER apply any kind of coating to any bolt that is a TTY bolt.
  17. Mar 21, 2013 at 6:55 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Denso and NGK both have write-ups about their zinc coating on the spark plug threads. It is no longer necessary on quality plugs with coating already applied. However, they do mention that cheap, crappy plugs with black threads that tight-wads use absolutely still need anti-seize. I know this info is hard to take for some, but it is what it is. I replace plugs as part of a 120k service, and I have never had an issue with stuck plug threads, and that is with Denso coming out, and Denso going back in. Trust me in saying that Toyota and Lexus don't anti-seize anything. If you want to use the stuff, go ahead, but don't sweat it if you didn't.
    Correction, they anti-seize the AF sensor threads, but that gets nasty-hot.
  18. Mar 21, 2013 at 8:11 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Put a little on the threads of your sparky plugs.
  19. Mar 21, 2013 at 8:13 PM
    Spoonman
    Jamie
    Alberta
    What's an AF sensor?
  20. Mar 22, 2013 at 6:13 AM
    Vstrom30
    Midwest
    Air fuel sensors. New Toyota replacement AF and O2 sensors come with anti-seize already on the threads.
