Anti siphon caps for Rotopax?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skweezal, Feb 2, 2025.
  1. Feb 2, 2025 at 11:14 AM
    skweezal
    skweezal [OP] Well-Known Member
    Wondering what you like for anti siphon caps for your Rotopax. Thanks! I have the locks so they will no be able to be removed from the Molle Boards, but also want to make sure the gas isn't nabbed!!
    Thanks!
  2. Feb 2, 2025 at 11:21 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Haven't had to worry about that yet. I do have some locks that I only used once when I was in Fresno. Only other time I had a concern was when I had to leave my truck for a few days and forgot to take the Rotopax off. Then I just put it in the bed under the tonneau cover.
    skweezal[OP] likes this.
  3. Feb 2, 2025 at 11:22 AM
    Bishop84
    Bishop84 Well-Known Member
    I can tell you people use drills for any fuel, its rare we see siphon damage anymore.
    Chew, auskip07 and skweezal[OP] like this.
  4. Feb 2, 2025 at 11:27 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Let the thieves get that and not drill your Tacoma fuel tank.
  5. Feb 2, 2025 at 1:32 PM
    dryheat
    dryheat Well-Known Member
    Last year we had several work trucks ripped off on several different occasions. Each time they just drilled a hole in the gas tank, they don't even bother siphoning.
    Chew likes this.
