Anti stall with 6MT?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T$$, Jan 7, 2017.
  1. Jan 7, 2017 at 12:37 PM
    T$$
    T$$ [OP] Well-Known Member
    2017 TRD OR MT
    I didn't see it in the manual but does the 6MT have an anti stall feature for crawling? Similar to the Wranglers.
  2. Jan 7, 2017 at 12:38 PM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Yes, your left foot
    Michal006, GPsevinSixx, 0210 and 8 others like this.
  3. Jan 7, 2017 at 12:46 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Clutch Cancel Switch will help thru rough areas.
    tonered likes this.
  4. Jan 7, 2017 at 1:47 PM
    T$$
    2017 TRD OR MT
    Thanks for the insight Einstein.
    I'm referring to crawling in 4LO without pressing the gas since the torque from the engine keeps the truck going.
    I'll just try it myself sometime. Was just curious if anyone had done it already.
  5. Jan 7, 2017 at 1:50 PM
    shakerhood
    Southern Ohio
    Clutch Cancel let's you use the Starter Motor.
  6. Jan 7, 2017 at 1:58 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Non TRD Offroad Longbed Problems....I wouldn't know
  7. Jan 7, 2017 at 2:01 PM
    RIDERED67
    The wranglers have a clutch start cancel feature which is designed to allow you to start the jeep without depressing the clutch.
    It is not designed to keep the jeep moving at a low speed as Toyotas crawl control feature does.
    Sooo...not really sure what your axing...
  8. Jan 7, 2017 at 2:01 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I'm not sure if it's a separate system or not, but you can crawl pretty well in 4lo 1st gear without throttle input (I don't rock crawl or the like, so I couldn't tell you about that). May just be the combination of the ECU idle speed adjustments in concert with the torque multiplication in 4lo.
    Frank
    shakerhood and Trips222 like this.
  9. Jan 7, 2017 at 2:39 PM
    Trips222
    Trips222 Well-Known Member
    Tim
    Baltimore MD
    '16 DCSB OR MT
    3 Kid Seats
    Just used it today at an Offroad park. It is by no means automatic, but for the reasons Frank gave above it does a pretty good job keeping rpms up. By the end of my day I found myself modulating the gas more than the clutch.
  10. Jan 7, 2017 at 2:51 PM
    shakerhood
    Southern Ohio
    There is no Crawl Control on the 6 Speeds.
  11. Jan 7, 2017 at 4:44 PM
    T$$
    2017 TRD OR MT
    Cool yeah. That's what I was getting at. I'll try it out next time I use 4LO. Thanks!
  12. Jan 7, 2017 at 5:15 PM
    Stockotaco
    Stockotaco Well-Known Member
    Ben
    2016 Inferno TRD Off Road 4x4 w/man pedal
    All Stock
    Isn't there a feature that allows you to bump the starter while the truck is in first gear? Sort of like a poor mans crawl control for the manual transmission.
  13. Jan 7, 2017 at 6:15 PM
    Trips222
    Tim
    Baltimore MD
    '16 DCSB OR MT
    3 Kid Seats
    • Yes, the clutch start cancel button.
    MOC221_ and shakerhood like this.
  14. Nov 5, 2019 at 4:05 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Alright this is an ancient thread - but in my experience the engine doesn’t idle high enough to climb over obstacles without stalling, or making terrible knocking noises
    is there any way to put in a high idle switch on these trucks for off-roading?
    — short of my right foot, of course ;)
  15. Nov 5, 2019 at 4:08 AM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    4HI in the 6MT is a great way to burn a clutch up off road. 4LO in 2 and enjoy.
  16. Nov 5, 2019 at 4:12 AM
    AKGSD
    Joe
    Alaska
    Oh i was using 4Lo. But in places like Moab or Engineer Pass, there’s still just not enough torque multiplication for the 500rpm idle to handle given it’s low torque output.
    i don’t even like it’s low-rpm creep in a parking lot, let alone over rocks
    this should work
    https://www.yotatech.com/forums/f2/high-idle-switch-anyone-198737/
