Anti-theft Rigids?
Discussion in 'Lighting' started by PhantomVirus, Sep 25, 2012.
  1. Sep 25, 2012 at 7:40 PM
    PhantomVirus
    PhantomVirus [OP] Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    So I am about to buy a 20" LED light bar and 2 Duallys which is near a grand in lighting.
    Any recommendations on making them hard to steal? I don't see LED lights much and you have to believe that folks that steal things know that they are pricey.
    Thoughts & recommendations appreciated. I know I can use Loctite to make the mounting bolts impossible to remove but I may want to take them off some day so I want 'permanent' mounting not "PERMANENT" mounting ;-)
    Thx
  2. Sep 25, 2012 at 8:22 PM
    RigidIndustries
    RigidIndustries Built To Be Seen
    Gilbert, AZ
    We offer a Security Nut Kit for the E and SR Series Light bars. Any one of our dealers should have them in stock or they can be purchased on our website. As for the Duallys depending on their location you can double nylock them making it more difficult to dismount them. If you have any other question feel free to ask or you can call the office anytime and we would be glad to help you out.
  3. Sep 25, 2012 at 8:34 PM
    PhantomVirus
    Ron
    Thanks Dan - welcome to the board!
  4. Sep 25, 2012 at 8:35 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    subd need this info...was wondering the same i just purchased some and wanted to keep them lol
  5. Sep 25, 2012 at 8:41 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    these work very well. you tighten them down like any other nut/bolt, but when you reach the specified torque, the hex portion snaps off, leaving a cone shaped nut. chanel locks, vise grips, etc will not get them off. you have to grind them off. it's a quick job grinding them off at home if you need to remove the bar, but it'll stop a theif in the middle of a parking lot.
    http://businessimpex.com/vishwakarmaimpex/shear_nuts.html
  6. Sep 25, 2012 at 8:48 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I just use hopes and dreams.
  7. Sep 25, 2012 at 8:50 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    try after try, when you try to clamp the vise grips, they just slide right up the cone. key is using a hard allow that the vise grips can't dig into. i've tried myself with about 5 different pairs of grips and pliers. no luck.
    i'm sure they'd grab one like the top left of the link, but that's why you use the steeper sloped ones, like the one just below it.
  8. Sep 25, 2012 at 8:58 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    interesting, maybe some threadlocker?
  9. Sep 25, 2012 at 9:12 PM
    DEZERT TOY
    DEZERT TOY Well-Known Member
    David
    Albuquerque N.M / SoCal
    Camburg LT Double Cab
    Camburg, Deavers, Fox, Glassworks
    I had enough thread so I welded the bottom of the stud so someone could back the nut off but no possibility of taking the nut completely to remove the light.
  10. Sep 25, 2012 at 9:14 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, antitheft is is a lot easier with a welder.
  11. Sep 25, 2012 at 9:21 PM
    Spoonman
    Jamie
    Alberta
    Or ruin the threads with a chisel.
  12. Sep 26, 2012 at 12:15 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
  13. Sep 26, 2012 at 7:39 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i would just tac weld a cap over the ends.
  14. Sep 26, 2012 at 7:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If someone really wants them, they're going to get them... They can either break the bolt or cut the bolt regardless of what you do. Personally, I'd use threadlocker red. With a little heat, threadlocker can be broken and the nut can be removed. Without the use of heat, you might break the bolt before the threadlocker lets go. The point is, threadlocker is easy and NOT permanent, at least not threadlocker red or blue...
