anti theft via relay
Discussion in 'Toyota Trucks & SUVs' started by lunch box, Aug 14, 2013.
  1. Aug 14, 2013 at 2:17 AM
    lunch box
    lunch box [OP] diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    Im thinking of installing a relay with the coil side connected to the cigarette
    lighter and the switched side on my ignition switch side, so basically you need to push the cigarette lighter in to start the engine, any thoughts im wondering if it might draw to many amps and blow a fuse, I know I can check the circuit and using ohms law figure it out, but anyone ever done anything similar using a relay as anti theft using existing switches?
  2. Aug 18, 2013 at 9:19 AM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    so anybody?
  3. Aug 18, 2013 at 9:22 AM
    acdronin
    acdronin Well-Known Member
    Interesting idea, i imagine the coil fuse is a big one, hence the need for a relay, sounds like it would work
  4. Aug 24, 2013 at 2:32 AM
    lunch box
    2000 trd tacoma
    I will try this mod soon, right now im still dealing with urd 7th injector upgrade tomorrow is the fuel pump day so ill get around to it. but from my experience say the amp draw is higher than normal usually it will blow a fuse but it takes about a minute or two to blow a fuse the cigarette lighter will act as a momentary switch and not cause enough heat to blow a fuse, ill figure it out soon and useing ohms law, I assume it will cause a larger amp draw to trigger the relay so it may need larger wiring, once you use larger wiring you could use a larger fuse once again using ohms law, also it is standard to go a few amps larger, so itll take a bit but ill figure it out and post it.
