Anti Theft ?!?!?!??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodsman2020, Aug 31, 2024.
  1. Aug 31, 2024 at 9:57 AM
    Woodsman2020
    Woodsman2020 [OP] Member
    2021 Tacoma SR
    Okay, my truck has disabled the ignition 4 times now. The key won’t rotate. The anti theft flashes but that’s the only sign. I usually disconnect the pos side of the battery to reset the computer. (15-30 mins usually works) Not today though. Idk what is in the hell is going on but I’m getting mad. Ha I’ve owned the truck for 6 months it’s a 2021.
  2. Aug 31, 2024 at 11:17 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Any chance that when you parked it the steering wheel lock was binding against the stops?
    Sometimes that can prevent the key from turning.
    RIX TUX, Chew and RedWings44 like this.
  3. Aug 31, 2024 at 11:23 AM
    Woodsman2020
    2021 Tacoma SR
    I’m on a slight incline, and my steering wheel is slightly turned to the right. I can’t rotate my steering wheel either. So I’m figuring you’re correct. How do I go about this problem now. Teach me…ha. Thank you!
  4. Aug 31, 2024 at 11:30 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I'd start with wiggling the steering wheel per above post.
    Pull down on it a hair on either side ( East/West ) and see if that will loosen it.
    Just a hair.
    Then wiggle the key left/right.
    See if you can get a pal or 2 to 'push' from the front of the truck just a hair as well.
  5. Aug 31, 2024 at 11:38 AM
    Woodsman2020
    2021 Tacoma SR
    Well, I got it. Not sure what actually jared it loose but now the ignition turned. I appreciate the help.
    Now, I’m assuming this happens when the vehicle is off, and the steering wheel is moved in one direction till it stops rotating. Correct assumption? I was working on installing some seat jackers. I must have grabbed the steering wheel.
  6. Aug 31, 2024 at 12:14 PM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    The wheel locks when the car is off and you try turning the wheel at all. Dont think the push to starts have it but it's a thing on most vehicles. Usually jiggling/ turning the wheel while turning the key unlocks it and starts the car.
    RIX TUX likes this.
  7. Aug 31, 2024 at 12:39 PM
    Woodsman2020
    2021 Tacoma SR
    Learned something new today. Thank you!
  8. Aug 31, 2024 at 12:58 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    key wont turn because the steering wheel is locked hard to one side has been going on for about 50 years :anonymous:
    Chew and BillF1564 like this.
  9. Aug 31, 2024 at 1:08 PM
    Woodsman2020
    2021 Tacoma SR
    Must have been a common mustang problem then. Ha
  10. Aug 31, 2024 at 1:16 PM
    RIX TUX
    steering wheel dont lock on the mustang
    did you read the owners manual for your tacoma?
    its user friendly
