Antifreeze leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1000cat, Sep 11, 2016.
  1. Sep 11, 2016 at 5:54 PM
    1000cat
    1000cat [OP] New Member
    kevin
    seattle
    sr5 4x4
    stock
    1999 v6 it's not the thermostat but between the block and timing cover can see it with mirror and flash light is this just a gasket and fixed when you do the timing belt and water pump ?????
  2. Sep 11, 2016 at 7:05 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    It's Probly the pump itself weeping. But yes. Timing belt/water pump kits come with everything you need. Get from aircabinman on eBay. He has a few different kits depending on how much you want to include.
    There could be a possibility that it's leaking from the gasket, but if so you've got an internal leak like from the bypass tube. Not sure on that though. That usually leaks out the back of motor. My money's on the pump.
