Antifreeze other than Toyota brand
Discussion in '3rd Gen. Tacomas (2016-2023)' started by knuckles67, Sep 27, 2020.
  1. Sep 27, 2020 at 5:47 PM
    knuckles67
    knuckles67 [OP] Well-Known Member
    Derek
    What is everyone using for antifreeze beside Toyota brand
  2. Sep 27, 2020 at 6:43 PM
    Tacospike
    Two Trucks
    Anything other that’s pink, but mainly Toyota / Lexus brand?
  3. Sep 27, 2020 at 6:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've been using whatever is on sale for the last 20 years. The color means nothing.
    wilcam47 and whatstcp like this.
  4. Sep 27, 2020 at 7:10 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    most will end up .........mixing ............
    the worst thing anyone can do
    the anti freeze makers & the car manufacturers cover thier azzzes with a simple caveat
    mostly to cover that near emergency situ so that the driver/vehicle can continue
    adding anything isnt short term is Not terminal
    mixing the pink
    orange
    green
    of diff brands same color will result to swill inside the engine
    coolant makers have their own dedicated formulas
    if U have good reason to change F L U S H with straight water then fill with what U have
    this time o year not likely to freeze & lose an engine
    Key-Rei likes this.
  5. Sep 27, 2020 at 7:23 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Why not use Toyota's coolant?
    All I use is (non diluted) Toyota Extra Long Life coolant (red not pink) and distilled water.
    Never had an issue still on the original water pump.
    I wouldn't mix coolants or use other stuff, Toyota formulates their coolants to lubricate their parts and protect their alloys appropriately.
    If I *HAD* to use something else in a pinch I would use pretty much any "asian" formula coolant and then replace again at home.
    It's not that expensive considering you only need to replace coolant like every 2 years or so. What are you saving by using aftermarket? It's not like it's going to cool better.
    Coolant is anti freezing agents, lubricants, and, corrosion inhibitors. What actually exchanges engine heat to atmospheric air is the water itself and you can't get "better" water than just pure distilled water so...
    Why not use OEM?
  6. Sep 27, 2020 at 7:48 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Ummm, no you don't? Unless you drive 50k miles every year...
    A coolant replacement every two years is way overkill.
    whatstcp likes this.
  7. Sep 27, 2020 at 8:09 PM
    axulsuv
    axulsuv Trials Rider
    Glenn
    Conifer Colorado
    2018 white double cab sr 4x4
    Tyger Flares % bed cover , intermitant wipers ...
    Little known detail ; Factory Toyota coolant is flammable and also has coagulating properties {slows minor leaks ...}Read the label about the flammable part , a instructor@tech school in Torrance explained that other feature to me about 40 years ago ...
  8. Sep 27, 2020 at 8:20 PM
    Key-Rei
    Key
    Florida
    A *lot* may have changed in 40 years but you've piqued my curiosity, I'll read the label of my Toyota stuff again when I get home, don't recall anything like that.
  9. Sep 27, 2020 at 8:21 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    After doing a bit of searching the web I found Pentofrost A4. Would that be an acceptable aftermarket replacement coolant? Looks like its available at Advanced auto parts near me for about $20 a gallon premixed.
