antifreeze
Discussion in '2nd Gen. Tacomas (2005-2015)' started by James's blue taco, Dec 14, 2009.
  1. Dec 14, 2009 at 8:36 AM
    James's blue taco
    James's blue taco [OP] Member
    james
    NM
    07 4x4 SR5
    K&N intake Snuglid bed cover tacoma seat covers and dash mat Aero Cat-back exhaust UniChip computer programer 265/65 Nitto terra grappler tires
    i got my 07 and im running low on antifreeze, i bought some of the extended life 50/50 mix sold at my work which is oreilly auto parts. is it safe to mix it with the original pink antifreeze
  2. Dec 14, 2009 at 8:43 AM
    KINGY2
    KINGY2 Member
    No .......use only toyota super long life coolant !
    And it is also premixed .
  3. Dec 14, 2009 at 9:39 AM
    sonjay
    sonjay Well-Known Member
    Do not mix anything but Toyota LL with the factory coolant. You can also buy it non pre-mixed which is much more bang for your buck.
  4. Dec 14, 2009 at 10:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you still under warrantee?? If YES, have the dealer top it off for you.
    You shouldn't be loosing fluid unless you're leaking it somewhere. Look around for any signs of fluid leaking (dried antifreeze around hoses, etc).
    I have an 07 and my radiator cap was leaking causing my overflow tank to get low. I took it to the dealer and told them the cap was leaking. They replaced the cap and topped off the fluid - all under warrantee.
