Antigravity Lithium Ion Battery?
Discussion in 'Technical Chat' started by KenLyns, Oct 7, 2012.
  1. Oct 7, 2012 at 9:41 AM
    KenLyns
    KenLyns [OP] 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  2. Oct 7, 2012 at 9:48 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Never heard of them... But a lighter battery on a motorpickle or quad seems to be a good thing to me... :notsure:
  3. Oct 7, 2012 at 11:13 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Just my opinion: For a starting battery, nothing is going to dump the amps needed quickly like a lead acid or it's related cousins. Remember that no matter what you do a battery in a vehicle is abused. Subjecting them to heat and cold constantly just isn't good for them. Buy a cheap battery that has the needed amperage to start your truck and save your money.
  4. Oct 7, 2012 at 1:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They seem to focus on starting, rather than power reserve. If you run a high power stereo, or off road lights, I would think the battery could be toasted pretty easy. And 720 CCA's isnt much. I try to keep a battery in my truck with 900CCA's or more.
  5. Oct 7, 2012 at 1:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    When the technology checks out I'll buy several of these.
  6. Oct 7, 2012 at 2:43 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    You might confirm that your vehicle's charging system and battery charger will produce the battery manufacturer's recommended absorption and float charging voltages. Li-Ion has a better capacity (amp hour/RC) per weight ratio and lower self-discharge rate than lead-acid, but at a much higher cost. The minimum performance (CCA), should based on the coldest temperature you operate your vehicle in. If you want to use a sealed "dry" battery, you might also consider a flat plate or spiral wound AGM VRLA battery.
    For additional information on lead-acid batteries, please see Sections 7 and 9 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
  7. Oct 7, 2012 at 4:22 PM
    KenLyns
    Belly of the Beast
    I have no problems starting in the winter with the OEM battery. Looking at Li-ion more for the weight savings. Something like the YTX12-24:
    720 CCA
    22 Amp Hours
    weight is only 5.0 lbs
  8. Oct 14, 2012 at 5:48 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    If you are using your truck for racing and it matters that much. But my heavy battery works just fine for my sound addiction and my truck starting.
  9. Jun 24, 2014 at 11:06 AM
    skygear
    skygear                    
    People are buying these again! Group BUY!
  10. Jun 24, 2014 at 11:08 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
  11. Jun 24, 2014 at 11:12 AM
    skygear
    skygear                    
    Nice. Well, until it hits the market, we are still on Lithium.
  12. Jun 24, 2014 at 11:36 AM
    skygear
    skygear                    
  13. Jun 24, 2014 at 7:33 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    I seem to remember some old guy using one of these in his car a few years ago...:rolleyes:
  14. Jun 24, 2014 at 11:05 PM
    skygear
    skygear                    
    Lol. And we are almost to that measurement too :facepalm:
