Antiknock CPU
Discussion in 'Technical Chat' started by 876653289, Dec 1, 2009.
  1. Dec 1, 2009 at 7:52 AM
    876653289 [OP] New Member
    K&N intake, airaid throttle spacer
    I keep getting an engine light and when checked it comes up as code P1605Knock Control CPU Malfunction
    Can anybody tell me more about this. Most tell me its a knock sensor but it looks like that should be a seperate code for each knock sensor since this engine has 2 of them.
  2. Dec 1, 2009 at 8:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I dont have any experiance with that, but bump for someone else who may know....
  3. Dec 1, 2009 at 8:35 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Oh boy, that's a bad one. The flow chart goes like this:
    DTC P1605; Engine Control Computer Malfunction (for knock control)
    Trouble Area - ECM
    Are there any other codes present?
    NO? Replace ECM
    YES? Go to relevant DTC chart
    So, if there are no other codes along with the P1605, you need a new ECM (computer)
  4. Dec 1, 2009 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek: Good to know! Thanks Kev!
  5. Dec 2, 2009 at 5:30 AM
    kevhogaz
    SR5 PreRunner
    I hated to even post the answer to his problem, because it was an expensive one to fix.
    I'd look for a used one first, then go to the dealer second.
