Any 12' owners get brights flashed at them a lot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by btipsword, Dec 9, 2012.
  1. Dec 9, 2012 at 2:48 PM
    #41
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Just park on a level location in front of a wall. Measure the center of the bulb on the truck. Go to wall and mark that height on the wall and adj drivers side bulb to just below that mark and the pass. side to that mark but not above.
    Just do it and be done with it and don't be a dick to other drivers.
    You wouldn't by chance have your fogs on? That will shine them also.
  2. Dec 9, 2012 at 4:20 PM
    #42
    dantastic
    dantastic Well-Known Member
    818<->626
    2012 DCLB 4x4 BLK
  3. Jan 9, 2013 at 2:23 PM
    #43
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 4cyl MT 4x4 Utility Package
    Funny I came accros this,
    My 2012 RC was the same way, the headlights were set very high in comparison,
    I wrote service as a Service Writer for 10 years, and I got flashed so many times I went out and marked the top spot on the adjuster with a sharpie and turned em down a bit. Also in NC we have a state inspection standard, but new cars on dealer lots I thought didn't have to pass a headlight aiming test/adjustment.
    I am very happy with them and don't get flashed but maybe once a week.
    I also have higher power halogen bulbs too, so I really needed to adjust mine.
  4. Jan 9, 2013 at 2:39 PM
    #44
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    It takes 5 min and a screw driver. Too easy, just do it
  5. Jan 9, 2013 at 2:59 PM
    #45
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    My 2011 came with the lights shining in the second floor of houses. Pull up to a garage and adjust them one at a time put a jacket over the other one they should not be as high as the garage door handle if you are with in 10-15'
  6. Jan 9, 2013 at 8:06 PM
    #46
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Don't go by the garage door handle, and 10ft is too close to adjust.
    Federal spec is for the low side of the cutoff to be 2.1" below the centerline of the headlight when projected on a flat surface 20ft in front of the vehicle.
    Truck of course needs to be parked on a level surface.
    I used the back wall of Lowe's.
  7. Jan 9, 2013 at 8:10 PM
    #47
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Columbia, SC
    2015 DCSB 4x4 trd offroad
    Ome 885, dakars, lr uca, bed bars sos sliders
    I adjusted my lights up a little.. I did it for the deer around here.. and I love it.. drivers on the other hand.. eh...not so much.. but then do the same and just blind them w/ my brights.. ;) i'm so gonna get shot one day.. but oh well
  8. Jan 10, 2013 at 1:04 AM
    #48
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I never got flashed when I owned my '11. I got flashed last week in my '13. It was the only time that I have gotten flashed in the 2 months of ownership. I was going down a bumpy road and I think that's what it was, it hasn't happened since then.
    A buddy of mine has a lifted, none Toyota truck and he never adjusted his lights. He ended up getting aftermarket, cheap, chinese HID's and it's brutal. I've given him shit because when I owned a car it would go right into my rear view mirror. He wouldn't adjust them, he just laughs at me. I told him that one of these days you're going to piss off the wrong person because you're too lazy to adjust your headlights.
    OP: In the time that you made this thread you could have went out and adjusted your headlights. Stop being lazy and go and do it. We know it's hard to take time out of your day to do something that could end up saving someone from an accident, including yourself. I'm sure that you're going to wish that you adjusted your headlights if an oncoming, bigger vehicle comes headed in your direction because they are blinded by your ignorance.
  9. Jan 10, 2013 at 9:29 AM
    #49
    trot
    trot 兔年快乐! 慢慢走!
    Aberdeen Proving Ground
    i get brights flashed at night in my 2011 stocker.
    i did the basic test on my garage wall, you know to check to see if either light was off, and it didn't appear that way at all.
    it's not like the stock headlights are even good really, i think it's because the roads around my place are very narrow and people get that line of sight stare thing going on narrow roads at night, looking into oncoming traffic rather than looking at the white sideline to avoid glare.
    never happens up on the four lane
  10. Jan 10, 2013 at 9:33 AM
    #50
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    Never happened to me in my 2012.. but half the time I forget to turn my headlights on before im halfway down the road.. so it could just be that I dont notice.
  11. Jan 10, 2013 at 9:35 AM
    #51
    SaveAHoRideATACO
    SaveAHoRideATACO Pro Tech
    Lake Harding, AL
    07 PreRunner TRD Off-Road 2WD
    3" Coil Spacer Lift to Front; 1.5" Add-a-leaf to Rear
    I have an 07 and have been getting flashed ever since I bought it new back then. It was completely stock until this past spring when i gave it a mild lift. I still get flashed at times and people still act stupid when I'm right behind them at night, but I can't help it. I'm not adjusting what came stock from factory/dealer. I like my ligths just the way they are. The lift had no effect on people flashing me; they were doing it before and are still doing it now. It's only occasional though, so I write it off as a character flaw on their part. haha
  12. Jan 10, 2013 at 3:33 PM
    #52
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Alot of hardass improper headlight users in here.
  13. Jan 10, 2013 at 6:59 PM
    #53
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Remember that any change in elevation will cause at least one person to be looking directly into the head light bulb.
    But for the most part, when I drive around in me (new :woot: ) civic, it looks like trucks have their brights on, even on level surfaces.
    If a truck is "right" behind me, as SaveAHoRideATACO said, it also looks as if the brights are on. These people are usually tailgaters, so when a drivers "act stupid" it may as well be justified.
  14. Jan 10, 2013 at 7:00 PM
    #54
    TeamSarcasm
    The better coast
    I blame my phone for all wording and grammatical errors :p
  15. Jan 12, 2013 at 10:56 PM
    #55
    jw1983
    Alberta
    "Stupid" doesn't discriminate against age, race, gender, or sexual orientation.
  16. Jan 12, 2013 at 11:18 PM
    #56
    Mr. Brown
    Mr. Brown Well-Known Member
    Orange County
    White Double Cab Off Road
    Suspensiopn: Donahoe coil overs, Donahoe rear reservoir shocks, Light Racing UCA's, Wheelers AAL's, Exterior: Powder-coated black billet grill, Hella Black Magic fog lights, color matched rear bumper, color matched side mirrors, undercover tonneau cover, Interior: Alpine W203 w/ Blackbird II, Weathertech Floor-liners, blue gauge light mod, Performance: AFE Stage II Intake, Banks exhaust, single cat y-pipe, Dynomat hood-liner, NST Performance pulleys, URD MAF calibrator
    3" lift with headlights properly re-aligned and I still got flashed a lot. The only ones I flashed back were the ones that went overboard with it (i.e. constantly flashing, leaving highs on, etc.)
    I also try really hard not to tailgate. Because it's dangerous and I'm aware of the fact that my lights were annoying to those in front of me when I did.
  17. Jan 12, 2013 at 11:25 PM
    #57
    CLynch
    CLynch Well-Known Member
    Charlie
    Upstate New York
    None
    Iget flashed all the time. t is not lifted. I just think the lights are brighter. My plans do not include attempting to adjust. Call it what you will, I think they are just bright. Much better light than my other vehicles.
  18. Jan 13, 2013 at 5:20 AM
    #58
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    +1
  19. Jan 13, 2013 at 6:22 AM
    #59
    SR52012
    SR52012 Well-Known Member
    Port Richey (Tampa Area)
    2012 Taco Pre-Runner SR5 3" procomp lift
    3" Procomp lift level kit N-FAB step sides
    I get it all the time... I have the 3" lift level kit from procomp. I think its funny when they get over slow down and drive behind me with there brights on.
  20. Jan 13, 2013 at 7:12 AM
    #60
    skulltacoma
    skulltacoma Make more better!
    BEN
    Calgary, AB, Canada
    2009 toyota tacoma trd modified
    CAI, dynomax turbo exhaust system,tinted windows medium on the fronts to match the backs, hid kit hi and low beam, pop and lock tailgate, painted calipers red with caliper paint, put 2.25' leveling kit in front and a 1" block in the rear. its now level and rides WAY better (readylift)>way nicer than the revtek my buddy has i think its garbage imo<, hurst "T" shifter, 18 x 10 american racing (can't remember the name) chrome rims with badass 5 inch lip :), 12 inch rockford fosgate punch with rockford fosgate 600 watt amp, bushwacker fender flares (cheaper than replacing the one i wrecked lol) ,kc light bar with kc lights, toyota aluminum stamped skid plate, and a skull front license plate. More mods to come, thinking a 6 inch lift and arb bumper etc etc.
    I drive a 2009 and i get flashed all the f-ing time. and i dont have a big lift in the truck right now just a leveling kit and slightly bigger tires. i used to run hids that just dropped in to the stock headlights. however i went back to some piaa bulbs and am considering doing the retro fit headlights with projectors and hids. people will hate them....
    people yes flashed me with the hids all the time.
    i still get flashed just as much with my normal halogens in the truck now. <--- which surprises me because they are no where near as bright as the hids.
    my solution flash them back... not once but twice... once with the high beams and while they are on, and if im quick enough the two kc 6 inch lights up front. ive been able to tell what color their skin is at night.
    i dont always do this but if they flash me and i flash them with the high beams and they go back to high beams ON.... then i let them have it.
