Any 12' owners get brights flashed at them a lot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by btipsword, Dec 9, 2012.
  1. Jan 22, 2013 at 7:50 PM
    #101
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Sounds like it probably is, but they are being considerate to the drivers heading the same direction you are.
  2. Jan 22, 2013 at 8:06 PM
    #102
    CLynch
    CLynch Well-Known Member
    Charlie
    Upstate New York
    None
    I have not used any vulgarities to describe my habits. My lights are within the specs set forth by Toyota. The people who designed the truck, and currently service it. Typically when something is spec, I would assume it is fairly precise. I am unaware of a sliding scale of spec. In dealing with machinery, spec is normally within given range. That range typically, is fairly small. I stated and openly retracted the all the time comment as it was a hyperbole.
    In case you are unaware
    Hyperbole
    1. Obvious and intentional exaggeration.
    2.an extravagant statement or figure of speech not intended to be taken literally,as“to wait an eternity.”
    To take what is found by the techs that are paid to service these vehicles and dismiss it is pure silliness. Your happiness would involve me taking my vehicle from spec and altering it in a manner that would negatively affect its performance. I will lower lights from what is in spec when you use corn oil as your engine oil. Better for the planet and all. All the cool kids do it. I want to add that sarcasm is the tone for the final few sentences. I would not want you to ruin your vehicle, so please do not try it.
  3. Jan 22, 2013 at 8:14 PM
    #103
    Rich91710
    Rich
    Los Angeles
    08 Base
    Just because a "dealer tech" looked at it doesn't mean it's in spec.
    I've had plenty of jobs mungled by dealer techs.
    Have you verified that the aim is correct? A lot of people assume that having the cutoff even with the lamp is correct, but it is not.
    It's an okay ballpark to get from home to some place where you can check properly.
    Federal spec (not Toyota) is for the low side of the cutoff to be 2.1" below the centerline of the lamp at 20ft.
  4. Jan 22, 2013 at 8:16 PM
    #104
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Peoples leaf springs are with in "specs" set forth by toyota yet they throw them out because they suck :p
    Also I would like to point out that if anyone is driving a newer truck, let things settle out before adjusting anything, assuming that you are going to take the time to do so. This statement does not change my opinion of people lifting and not adjusting ;)
  5. Jan 22, 2013 at 8:20 PM
    #105
    CLynch
    Charlie
    Upstate New York
    None
    Rich,
    You may be right. I do not think I would change what the dealer has stated as correct. Imagine getting an alignment and saying the tech is a bit off and begin to turn wrenches. If that is something you would do, you are a bettter mechanic than myself. A week ago it could be catorgorized as someone unwilling to fix the situation. I would agree to a point. The service tech today confirmed that my vehicle was within "spec". After the inspection by the service tech, I have to say that no change is in my future. The vehicles have all been small vehicles. To adjust for their eye level would destroy my front end. (deer and other creatures)
    Regardless, I really like you grill.
    Charlie
  6. Jan 22, 2013 at 8:20 PM
    #106
    jandrews
    '09 FourDubDee TRD OR
    My lights are adjusted where I like 'em. This is probably a tad higher than spec. I'm ok with it. I have yet to be flashed.
  7. Jan 22, 2013 at 8:22 PM
    #107
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Didn't they "forget" to throw in a cabin air filter in the 2005's also?
  8. Jan 22, 2013 at 8:22 PM
    #108
    scocar
    scocar hypotenoper
    These guys have it right.
    You are creating a safety problem by not adjusting after a front-end lift. They're just calling you out. And so am I. Be an adult and adjust your headlights. Check it yourself by using the FSM and your garage door with some tape. Maybe you'll learn something.
  9. Jan 22, 2013 at 8:31 PM
    #109
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Happens to me all the time every frigging night. I have a 2011. I too have Billys at 1.75" with the TSB spring pack and 265/75's.
  10. Jan 22, 2013 at 8:40 PM
    #110
    CLynch
    Charlie
    Upstate New York
    None
    I want to point out, as many people are pointing out their lifts and this issue.
    I have no lift, or oversized tires. My Tacoma is stock in relation to height. Nothing has been done to alter it in any way.
  11. Jan 22, 2013 at 8:43 PM
    #111
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    +1
  12. Jan 22, 2013 at 8:48 PM
    #112
    TeamSarcasm
    The better coast
    If you read the opening post, you will read the op has a lift. If you didnt have a lift should have said so from the get go instead of trying to defend your self, which made it seem as if you had a lift.
    Wait till the suspension settles out and and see where your lights fall.
    Regardless, dealers can be wrong. Ask me how I know :rolleyes:
  13. Jan 22, 2013 at 9:10 PM
    #113
    Jojack
    Jojack Well-Known Member
    Joel
    Lacassine LA
    2011 4 door long bed 4x4
    Bilstein 5100 at 2.5", 1" rear blocks, TSB 4 leaf pack, Wolf Springs Fab Custom tube bumper, anytime fog light mod
    I'm still trying to figure out what I need to do to my truck to get flashed as much as you guys! All I get is the occasional wave but have yet to see the first pair of knockers (•)(•) :)
  14. Jan 22, 2013 at 9:18 PM
    #114
    CLynch
    Charlie
    Upstate New York
    None
    ^^^^^^^^^^ best post in thread.
    I apologize for any unintentional misleading. I missed that. The flashers still flash. That was the point of my contribution.
  15. Jan 22, 2013 at 9:51 PM
    #115
    Rich91710
    Rich
    Los Angeles
    08 Base
    You just need a Leykis-101 sticker ;)
  16. Jan 23, 2013 at 5:29 AM
    #116
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Just ran into the back of the garage, but my brakes are with in specs. So I'll just leave them.
    Sorry, no boobs.
  17. Jan 23, 2013 at 6:18 AM
    #117
    TeamSarcasm
    The better coast
    ^ brake lights are a different matter buddy, a problem I ,driving a civic, have never had a problem with. But thank you for admitting your driving skills ;)
  18. Jan 23, 2013 at 7:14 AM
    #118
    REDLARIAT
    REDLARIAT Well-Known Member
    Pikeville, Ky
    2012 Green TRD Sport w/ Chrome Wheels
    ARE bed cover, Chrome step bars, Tinted windows, Bull bar, Painted front spoiler, Chrome fog light rings, Chrome handle covers, TRD exhaust tip, TRD brake light cover, Custom hitch plug, Leather seats, Heated seats, Wood trim, Custom gun mount
    Stock truck here with no flashes. I do think my headlights could be adjusted up a little though. I find myself using high beam alot more on this truck than my previous vehicles.
  19. Jan 23, 2013 at 9:47 PM
    #119
    Markallyn86
    Markallyn86 I like tacos and burritos
    Mark
    Houston, TX /Heights
    Trd sport 4x4 2012
    OME kit 885, LR UCA, XD addict 17's, 265 70 Nitto, ultra gauge, weather tech
    I got flashed after lifting a lot. Then I adjusted them. I flashed a tundra last night that was lifted with hids :cool:. That asshole was blinding the shit outa me.
  20. Jan 24, 2013 at 8:56 PM
    #120
    Rich91710
    Rich
    Los Angeles
    08 Base
    The new GM trucks are horrible.
    Mine projected on a wall:
    And where the cutoff hits a small car:
    And no, I wasn't actively driving... we were stopped in the queue for a ramp meter.
