Any 2014 Driveline Vibe Fixes/TSB yet?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brizower, Jan 15, 2014.
  1. Jan 15, 2014 at 4:03 PM
    brizower
    brizower [OP] Well-Known Member
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    I bought my TRD OR back in October and now have 3kmi on it. The whole time I've had a pretty rough vibe in the middle of 2 gear under acceleration and a few other vibes here and there.
    I called the dealership a couple weeks ago looking to get another leaf added (mind came with 3 leaf) to solve the horrible handling and squatting when I have my 400lb 4 wheeler in the bed. They said they had no open TSB's for 2014's yet.
    Has anyone had any success fixing either of these problems yet?
  2. Jan 15, 2014 at 4:34 PM
    Tacoma Mike
    Tacoma Mike 42 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    A tsb is in the works. Should be available in a couple of months for vibes.
    Your best bet is custom leaf packs. Lots of info through here.
    Warning.
    Playing with aftermarket leafs and trying to get vib tsb work done will be an issue.
    One of the parts are new leaf packs.
    So you will need to decide to wait to see how this tsb goes or run the risk of not having anything done for your vib situation if you start modifying at this time.
  3. Jan 15, 2014 at 4:42 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Good luck. I had the now-repealed TSB done for driveline vibes on my 2012 and it didn't do anything. Putting my OME lift on actually got rid of the vibes though.
  4. Jan 15, 2014 at 6:03 PM
    brizower
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    I'd replace the leafs myself, but I want to lift it with the Fox 2.5 kit from Camburg when I've got the loot. Right now I'm just looking to solve the vibration and squatting for now.
  5. Mar 13, 2014 at 12:59 PM
    brizower
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    Picked up my truck today.
    I got 4 leaf packs, a steering damper, and an engine mount replaced under warranty.
    Problem solved.
  6. Mar 13, 2014 at 1:26 PM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Did the 4 leaf packs cure the "squatting" problem with your ATV in the bed?
  7. Mar 13, 2014 at 4:22 PM
    brizower
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    I won't know until I load it up next time. But I'd put my money on it did some the ride is a little rougher.
  8. Mar 13, 2014 at 5:00 PM
    TacoLarry
    TacoLarry Well-Known Member
    Larry
    PacNW
    14 Tacoma DCLB Myca Pyrite 4WD
    What did it take to convince them you had an issue? I've added some Hellwig 550EZ helper springs, but that is really a bandaid.
  9. Mar 13, 2014 at 5:40 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    show up with shit in your bed and complain...
    squeaky wheel gets the grease in this situation... my truck is FINALLY in the shop after 3 months of back and forth with the dealer on the driveline vibration tsb and rear sagging.... i bought my 2013 nov 2nd 2013.
  10. Mar 13, 2014 at 7:10 PM
    brizower
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    That's what I did, I called once and they said they couldn't help me, then I complained again at my first oil change and they actually looked at it.
    Bottom line. It's a brand new truck. It shouldn't need a TSB to get fixed. The vibe isn't normal and they should do anything within thier power to fix it under warranty.
  11. Mar 13, 2014 at 7:22 PM
    nd4spdbh
    SoCal
    there is a TSB to fix it... but for what ever reason they thought the 2014's didnt have the "problem" when they clearly do. Take the tsb printed out from here
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/254438-driveline-vibration-tsb-out.html
    the latest PDF's are in the 35+ page range. tell them it exhibits this exact problem and you want it fixed, tell them to talk to their district tech and they will get shit done for you.
    Be a dick about it, but make sure you have the facts (printed tsb) and knowledge to back it up.
  12. Mar 13, 2014 at 7:32 PM
    brizower
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    I'm right with you. Get them the info so you can avoid being hassled.
    However, TSB or not, there is a problem and it's under warranty so they have to fix it. If it was just one case of it happening they'd look at it and fix it, so it shouldn't be any different for multiple cases.
    I think my problem was due to it being a TRD Off Road and only having 3 leafs. My old 2012 SR5 and my buddy's 2013 Baja both have 4 leaf packs and they didn't have any issues.
  13. Mar 13, 2014 at 8:34 PM
    rusbob
    rusbob Active Member
    Pensacola, Fl
    2012 sr5 4x4
    My 2012 SR5 with 4 leaf had the vibe. The new TSB fixed it.
  14. Mar 14, 2014 at 12:25 AM
    brizower
    Andrew
    NorCal/Upstate NY
    2016 TRD Off Road
    Well shit.
    Now I'll never know.
