Any 22Re W-56 experts in here?
Discussion in 'Toyota Trucks & SUVs' started by Blue92, Dec 13, 2017.
  1. Dec 13, 2017 at 12:42 PM
    Blue92
    Blue92 [OP] Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Hello! I have a 1992 Toyota Pickup DLX 4x4. 194,xxx on the clock. 22re with w56 5 speed transmission. Lately I have been noticing a noise kind of like a whining sound coming from the either the transmission or the engine. It gets louder ar RPMs go up. Quieter as I go up in gears. Seems to go away when clutch is engaged. Any ideas? Truck isn't driven much, just noticed it seems to be getting worse as time goes on.
  2. Dec 13, 2017 at 1:20 PM
    Manwho
    Manwho Still ignoring the voices in my head
    15 a/c sport 4x4 884/ bilstien front OME Dakar/Nitro-charger sport
    87 4runner 2in B/L N' shit 96 4runner back burner project
    Troubleshooting over the internet is somewhat of a crap shoot, but if the noise goes away with the clutch pushed in it is usually the input shaft bearing on the transmission going out.
  3. Dec 13, 2017 at 1:32 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Ok. Got a second opinion. Definitely under the hood. Still there when clutch engaged but not as loud. Thinking water pump, as that could also explain the coolant leaks I've been having.
  4. Dec 13, 2017 at 2:41 PM
    Manwho
    Not sure what it would have to do with the clutch, but under the hood whining sound I would check the idler pulley bearing.
  5. Dec 21, 2017 at 9:34 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Clutch engagement is independent of everything under the hood. To me if you hear a wiring noise when the clutch pedal is depressed and gets much quieter when the clutch is let out (engaged) it sounds like a throw out bearing. It could be you have something else going on as well.
