Any Advantage to Going 265/70?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FL_TRD Sport, Aug 6, 2022.
  1. Aug 6, 2022 at 9:09 AM
    FL_TRD Sport
    FL_TRD Sport [OP] Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    My 21 Sport has the OEM 265/65x17 Toyo A30s on 4Runner TRD Pro 17x7 4mm offset cast aluminum wheels. I'm starting to do research on going to an A/T tire. Nothing too aggressive as I don't do any serious off-roading - was thinking along the lines of a Michelin LTX AT2 to keep as much of the on-road manners as possible. My question is, other than the extra 1/2 inch in height, is there any reason to go up to a 265/70, and would I have any rubbing issues with the 4Runner wheels and OEM mud flaps? My speedo seems to read about 1 MPH fast as it is now so I'm not too worried about the difference with the larger tires from that standpoint.
    Thanks and my apologies if this question has been asked already!
  2. Aug 6, 2022 at 2:50 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    I would. Unless you run the hwy 99% of the time and mpg is of #1 importance. Had the same exact wheels and 265/70s on with no issues at stock height.
    FL_TRD Sport[OP] likes this.
  3. Aug 6, 2022 at 3:05 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Nope maybe 10-20% highway. 1-2 MPG either way isn't going to be a huge issue.
  4. Aug 6, 2022 at 3:15 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Been running 265/70 16's on my sr5 for 2 years vs the stock 245/75 16's that came on it. Really haven't noticed any negative results. Both tires are about the same height, the 265 ones are a little wider. They seem to ride smoother.
    Starman2112 and FL_TRD Sport[OP] like this.
  5. Aug 6, 2022 at 3:18 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Because the offset of your wheel changed from +30mm(stock) to +4mm, you want to go with a taller to keep as close to the stock scrub radius as possible.
    A 265/65/17 on that wheel, would add 26mm of positive scrub from stock.
    A 265/70/17 on that wheel, would add 22mm of positive scrub from stock.
    You realize, the Michelin LTX AT2 in 265/70/17, is only available in load E; weighing in at 49 lbs?
  6. Aug 6, 2022 at 3:24 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
  7. Aug 6, 2022 at 3:28 PM
    splitbolt
    NW Arkansas
  8. Aug 6, 2022 at 3:30 PM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    No worries sir. I appreciate the point about scrub radius. Made me look it up and read about it since I had no idea what it was LOL. Now I do...sort of :)
  9. Aug 6, 2022 at 3:39 PM
    splitbolt
    NW Arkansas
    In short, it's the interaction between your steering geometry, tires and road surface.
    You're already at 26mm added scrub; 22mm added scrub is not much of an improvement. You'd need a 37" tire to get back to zero added scrub with a +4mm offset wheel
  10. Aug 6, 2022 at 3:48 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I upsized years ago from 265/70/16 to 265/75/16. Those overall dimensions are virtually identical to 265/65/17 and 265/70/17. In my case the larger tires were more common, with more options, and priced cheaper than 265/70/16's. It was a no-brainer for me, but I haven't priced 17" tires. It made ZERO difference in fuel mileage even when I went to E rated 265/75/16's. My speedometer and odometer were closer to being accurate with the bigger tires.
    I didn't specifically seek out the E rated tires, buy fell into a steal on a set of them. The ride was a little rougher, and the weight did make a difference in acceleration, but not fuel mileage. When those wore out I went back to P rated 265/75/16's.
    The extra 1/2" looks a tad better to my eye. Any advantage off road is going to be pretty small, but I don't see any downsides either.
