Any advice just broke 100k on 06 tacoma v6 trd pre runner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo73, Jul 23, 2012.
  1. Jul 23, 2012 at 5:42 PM
    toyo73
    toyo73 [OP] Member
    Floriduh
    2006 trd pre runner
    Any recomendations on maint that should be done around this time? Havent had any major issues except univeral joint and warped driveshaft but that was covered under warranty so besides regular oil changes what should be done thanks
  2. Jul 23, 2012 at 5:45 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    Change transmission fluid.
  3. Jul 23, 2012 at 5:46 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Also check the front/rear diff fluid. And on the driveshaft there are grease zerks that need to be checked every oil change, I forgot a couple times and had a u-joint go bad. Good thing toyota fixed my mistake for free though
  4. Jul 23, 2012 at 5:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Celebrate with a Hooker.[​IMG]
  5. Jul 23, 2012 at 5:51 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
  6. Jul 28, 2012 at 7:50 AM
    toyo73
    toyo73 [OP] Member
    Floriduh
    2006 trd pre runner
    Thanks for the info - I have heard that its not a good idea to change transmission fluid that it could cause problems has anyone had issues changing tranny fluid on tacomas
