Any battery gurus
Discussion in 'Technical Chat' started by sk8rjess, Aug 9, 2016.
  1. Aug 9, 2016 at 9:43 AM
    sk8rjess
    sk8rjess [OP] IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    Truck has been sitting for years and for some reason I didn't pull the battery. It's beyond dead.
    Google shows AGM batteries can be revived by running them in a parallel with a charger and another good battery. For some people you have to do this a few times. For me I'm on my 10th+ time with no luck but I think it's the charger i'm using. It won't get past 7v. I understand the charger is thinking it's likely a 6v battery but even when it reads as being fully charged it quickly drops back to 7v
    Anyone else have any advice?
  2. Aug 9, 2016 at 4:52 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    That's not a guaranteed fix for all batteries. You said "for years" which is probably well past the point of resuscitation. The idea is that most chargers won't charge if the target battery is almost completely flat. The second battery is primarily there to trick the charger. However it does take some current to even attempt this, your charger might be marginal on output.
  3. Aug 10, 2016 at 5:34 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Use an old style charger if available, the new ones are too smart. They sense the dead battery somehow.
  4. Aug 10, 2016 at 5:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Buy a new battery.
    Ran AGMs for years in my Z cars and Miatas. While they are good, and meet a specific purpose, they are not lifetime, nor magical.
  5. Aug 10, 2016 at 8:01 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I'll add this. If the battery was frozen while at zero charge the chances of a future are greatly diminished. That's in addition to the other factors.
  6. Aug 10, 2016 at 8:03 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    That looks like a scene from one of the Back to the Future movies for rigging power for the Flux Capacitor.....yikes!!
  7. Aug 10, 2016 at 3:59 PM
    CChampigny
    CChampigny Active Member
    Chad
    Calgary
    2013 DCSB
    Icon CDC coilovers, Icon 2.0 rear shock, Dakar Leafs, Konig Countersteer wheels, All Pro Skids, Apex Sliders, Apex front bumper, All Pro rear bumper, Access tonneau, LR UCA, BHLM, 285/75/16 Duratracs...I think that its
    I had success bringing an optima battery back from the dead using one of the newer smart chargers. The trick was I had to set the charger to assume it was a 6v battery until it was charged and then tell the charger that it was a 12v battery. It then charged to 12v and all was good. The instructions on the charger actually mentioned doing this for fully discharged batteries. The charger I used was a noco genius charger. Battery lasted a good 2 years after this. The battery probably would have lasted longer but my alternator started to die which caused the battery to never fully charge and that eventually killed the battery.
  8. Aug 11, 2016 at 1:30 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    New battery as a person who forgets batteries all the time.
    I am getting better only had to buy 3 since May
