Any Benefits For Upgrading UCAs If You Are Not Lifting?
Discussion in 'Suspension' started by JTB Tacoma, Sep 30, 2020.
  1. Sep 30, 2020 at 3:23 PM
    JTB Tacoma
    JTB Tacoma [OP] Well-Known Member
    Central NJ
    2015 Tacoma TRD, Super White
    Like the subject line says. If you are staying at stock height, or only lifting to level your height, are there any benefits that would make upgrading to a different UCA make sense? For example, I know some of them give some additional adjustments to caster and camber. Or, with what they are designed for, would changing to an upgraded UCA at stock height create problems?
  2. Sep 30, 2020 at 3:24 PM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    No and maybe. The only reason to upgrade UCAs is to correct camber issues after lifting. Sometimes, when you lift the front, the front tires will be tilted in at the top, negative camber. Aftermarket UCAs will be a little longer to push the top of the tires out.
  3. Sep 30, 2020 at 4:07 PM
    mikelh
    mikelh Well-Known Member
    Mikel
    Atlanta
    2016 Tacoma / 2010 FJ Trails Team
    Been trying to find the answer to this! I know on the FJs its almost a necessity to put on UCA. Not sure if it's the same with Tacomas with a 2-3" leveling lift.
  4. Sep 30, 2020 at 4:32 PM
    lamjam
    lamjam Well-Known Member
    Los Angeles
    2021 TRD Off road 4x4
    I just leveled my front with the rear. Got the extended foxes with jba arms in the front so I can gain the extra down travel
  5. Sep 30, 2020 at 4:55 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    This. You can allow for more over all wheel travel while still keeping the stock ride height (how I have my camburg 1.25” uniball uppers and 2.5 extended icon c/o). As for the alignment the aftermarket arms may(?)give you more caster at a stock ride height which is good If you like a stable ride , not like a furniture dolly lol.
  6. Sep 30, 2020 at 5:02 PM
    su.b.rat
    su.b.rat broken truck
    that's not complete.
    the primary reason one would add aftermarket uca's to a non-lifted truck will be to add caster. keep your cambers at zero and add caster for highway driveability. stock uca's max caster is fairly low. increasing caster with uca's capable of more caster (and they are different one maker to the next) will add 2 or more degrees of caster depending on how you do your alignment.
  7. Sep 30, 2020 at 5:21 PM
    2000prerunner23
    steve
    It’s probably gonna depend on the UCA as well. Some are fixed and you would have to set it via the lower control arm alignment. Some UCAs have adjustable Heim pivots which would allow for even more adjustment. Some have a few settings for the ball joint position which lets u adjust as well. Point is yes the UCA will allow for more caster vs stock arms and alignment Windows
