Any body else have this whirring noise?
Discussion in 'Technical Chat' started by PINS Runner, Aug 14, 2014.
  1. Aug 14, 2014 at 6:19 PM
    PINS Runner
    PINS Runner [OP] Well-Known Member
    Larry
    Schertz, TX
    2011 DC TRD Off Road 4x4
    OME 885x coils with OME 9000 shocks, OME N182 rear shocks with AAL for TSB, LC UCA, 17x9 Moto Metal 909, 265x70 General Grabber AT2, hard Leer Tonneau cover (in fall & winter) Bestop Supertop (in spring & summer), Andres Devil Horns, WeatherTech FloorLiners (front & back), Air Lift RideControl air bags, ECGS bushing mod, Tom Wood's double cardan driveshaft, Matt123 skid plate, avid light bar, Rampage 22" LED light bar
  2. Aug 14, 2014 at 6:25 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Sounds sorta like a manual tranny in reverse or a strained power steering pump. If you have a supercharger then it is just supercharger whine.
  3. Aug 14, 2014 at 7:38 PM
    PINS Runner
    Larry
    Schertz, TX
    I wish, but no supercharger...
  4. Aug 14, 2014 at 8:40 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    alt bearings or the idler pulleys are the most common
  5. Aug 20, 2014 at 10:56 AM
    PINS Runner
    Larry
    Schertz, TX
    Ended up being the alternator. Dealership had to order it.......will be replaced on Friday.
  6. Aug 20, 2014 at 5:31 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Yep, my first thought was "that sounds like an alternator". Power steering pumps make a similar sound due to cavitation caused by low fluid levels.
    Glad you found it. You might be able to get a rebuild kit for your old alternator and keep it for a backup. If it is just the bearings that are bad, you can pick these up cheap at a local bearing house.
  7. Aug 20, 2014 at 7:42 PM
    PINS Runner
    Larry
    Schertz, TX
    Thanks for the ideas guys!
