Any body flex with the access cabs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kn38ms, Jul 17, 2010.
  1. Jul 17, 2010 at 6:50 AM
    kn38ms
    kn38ms [OP] Well-Known Member
    NW, FL
    Due to the lack of a pillar between the doors unlike the four door double cabs,
    do guys notice any flex in the cab?
  2. Jul 17, 2010 at 7:01 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Not me. I'm to old to flex.:(
  3. Jul 17, 2010 at 7:06 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Ummm...you do know the Tacoma isn't unibody??
  4. Jul 17, 2010 at 9:26 AM
    george3
    new jersey
    tacoma
    Are you implying that the frame made with inferior steel and the most useless paint job imaginable servers a purpose ?:confused:
  5. Jul 17, 2010 at 9:47 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I have had my rear tire up in the air from flexing and I didnt notice any.
  6. Jul 17, 2010 at 11:27 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Doesn't it hold the brake lines in place?
  7. Jul 17, 2010 at 12:03 PM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I'd think poly body mounts to make any problems worse since they have less give than rubber ones.
    I could see the back having problems (because of the C channel frame) but I'd have figure the front to be more solid. Even so: short of the doors binding what difference does it make? In a uni-body car body flex is pretty serious but that's just not a concern here is it?
  8. Jul 17, 2010 at 12:48 PM
    george3
    new jersey
    tacoma
    You are correct sir ! They hold my LED light strips so they do serve some purpose. :D
  9. Jul 17, 2010 at 12:53 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Yes there is a lot of flex on my access cab. My rear bumper will flix 1'2" up or down depending on how I am articulating. If you open your doors when you are flexed, you will notice your cab door does not inteferes when you try to close it. The whole truck does flex a lot.
  10. Jul 18, 2010 at 6:23 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Is anyone doing something like this:
    http://www.demello-offroad.com/catalog/product_info.php?cPath=27_60&products_id=108
    to the 2nd gen frames?
  11. Jul 18, 2010 at 6:30 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
  12. Jul 18, 2010 at 7:24 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I don't think it's nitpicky at all...I also am having some difficulty seeing what the issue is. I mean door binding and bed interfering with the cab may be an annoyance but in general flexing is much better than breaking (bending), and a structure that completely resists flexing without breaking under load will carry a huge weight penalty.
    Airframe structures are a prime example: wings of a 777 can move up and down 20 feet or more at the wingtip in flight using metals more prone to crack growth and fatigue than steel. They are designed for it.
  13. Jul 18, 2010 at 11:22 AM
    barlowrs
    Robert
    So Cal
    I agree, while I do see body flex in my frame, I do not find it to be a problem...heck, consider it an extra 1/2" of travel in my susp..haha
  14. Jun 6, 2013 at 8:07 AM
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    Anyone noticed any significant flex between the front of the bed and the cab?
    I'm thinking of putting my popup camper on the '09 TRD AC.
    I had it on my S-10, but the Taco is higher from the bottom of the bed to the top of the cab. I'm guessing I'm going to have to put some lumber under the camper to clear the cab top/fin due to camper's cabover/overhang.
    I keep the camper on HappyJacks under a carport when not in use and the clearances are pretty close as is, I'm just wondering how much extra I may need to shim it up to clear the cab and still fit under the carport.
    Thanks
  15. Jun 6, 2013 at 9:31 AM
    Crosis
    Crosis Well-Known Member
    Tampa Bay
    09 Tacoma 4x4 TRD Off Road
    If a frame is too rigid it will snap under load.
  16. Jun 6, 2013 at 5:46 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    I thought the rear doors flaked paint in the corners on the Double cab because of flexing?
  17. Jun 6, 2013 at 5:50 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I don't know about that, but I do know a couple guys with 05+ DC's that have stress cracks in that area from metal fatigue. No good way to fix it either. Sucks big time.
  18. Jun 6, 2013 at 5:54 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I think the infamous james did. And In2nite had his fram start cracking around his shock towers.
    both are extreme examples tho
  19. Jun 6, 2013 at 5:56 PM
    XXXX
    sKiP
    05 Prius
    whats that red light blinking bro?
    :laugh:
    James had some epic threads :bananadead:
