Any body found these or other good LR UCAs for a good or better price?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12taco, Jan 22, 2016.
  1. Jan 22, 2016 at 5:58 AM
    12taco
    12taco [OP] Cement to be
    Hunter
    Chattanooga, TN
    2018 Double Cab TRD Off-Road 4x4 Cement
    LED turns, brake, & reverse lights
    I found these Fabtech Uniball UCAs on www.headstrongoffroad.com for $575.99 and was wondering if thats a great price or some where else has them for better or even a different set that might be better for a better price just want to see some options and opinions! I have a 2012 Tacoma SR5 4x4 to be lifted 3" inches in the front and 1" in the back "ReadyLift SST kit" not gonna be doing "Offroading" just hunting driving through fields and very light stuff DD also. Help Please!
  2. Jan 22, 2016 at 6:04 AM
    Pigpen
    Dan
    Northwest Montana
    1. Those are not "LR" (Light Racing, a brand name) UCAs, but I'm sure they are of perfectly good quality.
    2. For the uses you mention, I wouldn't suggest uni balls. They require much more maintenance, and tend to be much noisier, than ball joint UCAs.
    3. In that price range, you should look at LR UCAs and JBA UCAs.
    MadDaddy likes this.
  3. Jan 22, 2016 at 6:08 AM
    12taco
    Hunter
    Chattanooga, TN
    Thanks sorry for the ignorance pretty much new to lifting and anything with suspension any suggestions on places to look?
  4. Jan 22, 2016 at 6:12 AM
    12taco
    Hunter
    Chattanooga, TN
    Light Racing Upper Control Arm Set for 05+ Tacoma
    $485.91
    from wheelersoffroad.com
    something like this?
  5. Jan 22, 2016 at 1:15 PM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    headstrong has LR brand UCAs for 375.00
    Maximus and MadDaddy like this.
  6. Jan 22, 2016 at 1:21 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  7. Jan 22, 2016 at 1:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    And don't hockey puck spacers. At least do 5100's all around
  8. Jan 22, 2016 at 1:55 PM
    12taco
    Hunter
    Chattanooga, TN
    where can I get them for under 600?
  9. Jan 22, 2016 at 1:58 PM
    12taco
    Hunter
    Chattanooga, TN
    I know its not the best lift but i mean all I will be doing is hunting and VERY VERY lift offroad ... like driving through a field
  10. Jan 22, 2016 at 1:58 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  11. Jan 22, 2016 at 2:00 PM
    12taco
    Hunter
    Chattanooga, TN
    do I need lift block to bring the back up level and I want 3" and ive seen where these only get like 2.5"
  12. Jan 22, 2016 at 2:01 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    What is your total budget to work with?
  13. Jan 22, 2016 at 2:08 PM
    12taco
    Hunter
    Chattanooga, TN
    Tires and lift 1300-1500
  14. Jan 22, 2016 at 2:08 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Not anymore 485.00 now.
  15. Jan 22, 2016 at 2:09 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    And you want to include tires/wheels and a full 3 inch lift with new UCA's for 1500.00?
  16. Jan 22, 2016 at 2:10 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    since when.
  17. Jan 22, 2016 at 2:11 PM
    12taco
    Hunter
    Chattanooga, TN
    Ucas are a maybe if alignment cant be done good
  18. Jan 22, 2016 at 2:11 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  19. Jan 22, 2016 at 2:12 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    3 inch lift you will need them
    Sterdog likes this.
  20. Jan 22, 2016 at 2:13 PM
    12taco
    Hunter
    Chattanooga, TN
    Guess it goes to 2k then
