Any climbers here?
Discussion in 'Sports, Hobbies & Interests' started by Buttermilker, Oct 20, 2020.
  1. Oct 20, 2020 at 9:48 PM
    Buttermilker
    Buttermilker [OP] Well-Known Member
    Danny
    Bishop, CA
    '16 ACOR
    Sierra pinstriping Eibach stage 1, 3 leaf AAL
    What have you climbed lately? The smoke on the eastside is killing all stoke, spread some of yours
  2. Oct 25, 2020 at 10:21 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Mountaineering guy here. Also ice climb but rarely rock climbing
    Ice climbing in a crevasse on Mt Baker and selfie from Adirondacks
  3. Dec 3, 2020 at 7:32 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I used to climb. Scuba and my truck took over my life for a while though.
    I never got into anything super technical. Mostly non-technical mountaineering like Shasta 5x plus 5 other CA 14ers and bouldering here and there.
