Any coffee heads?
Discussion in 'Food Talk' started by bongwhisperer, Apr 24, 2016.
  1. Dec 12, 2022 at 4:02 PM
    #481
    perlhammer
    perlhammer Well-Known Member
    Anyone have recommendations for an electric kettle with selectable temperature? Trying to decide between the Bonavita and Hario
    drewskie and 2Toyotas like this.
  2. Dec 12, 2022 at 5:55 PM
    #482
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I have a Bonavita electric kettle, and it works really well.
    The only small gripe I have is that if you hit the "temperature hold" button, it will only hold that temp as long as the kettle is on the base. Once you lift it off the base to pour, then set it back down on the base, you must hit the "temp hold" button again. But other than that, it's an excellent kettle.
    I've had mine for a couple years, and it still works great.
    I haven't seen the Hario electric kettle, so I have no idea how well that works. If I had to venture a guess based on the manufacturer (Hario), it's probably pretty darn good too.
  3. Dec 25, 2022 at 4:44 PM
    #483
    DuffyBank
    DuffyBank Well-Known Member
    Small batch roaster just across the border from me. Call them in the morning and they roast it then for pickup later in the day. Vienna roast of Sumatran had been my go to for my Gaggia classic pro
  4. Dec 25, 2022 at 4:48 PM
    #484
    Hercanstein
    Hercanstein Well-Known Member
    Bryan
    State of Jefferson
    1999 2.7 SR5 4x4 5MT XC, 2020 3.5 TRD Sport 4x4 6MT AC
    ('99) Offset Aluminium Wheels, 31" BFG All-Terrains, Bushwacker Fender Flares, Window and Hood Wind Deflectors ('20) Stock
    Peppermint flavored coffee for Christmas!
    Uh, with some Malibu.
    Sips of Fireball whiskey for warmups.
    : )B
  5. Dec 25, 2022 at 5:46 PM
    #485
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Sounds like life is rough.
    DuffyBank[QUOTED] likes this.
  6. Dec 25, 2022 at 5:54 PM
    #486
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Have a Dr Hetzner seems to work fine.
  7. Dec 25, 2022 at 6:02 PM
    #487
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Slightly off topic, but I just picked up a massive Bunn G1 grinder to use at home. I plan on turning it into a mini-bunnzilla, but it won't be for a while so I'll update once I do it.
  8. Feb 25, 2023 at 5:38 PM
    #488
    drewskie
    Drew
    Burbank, CA.
    Any of you guys brew with the v60? I've been using one for years but recently started messing with my grind and I think I ruined it. What size grind are you guys using for the v60?
  9. Mar 4, 2023 at 11:04 AM
    #489
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    I do use a V60, but I have a hand grinder. Can't give you an accurate size because it doesn't have settings. I generally grind it the same size that I use in my drip coffee machine.
    I bought a new Hario device recently, a Hario Switch. It's a pour-over device that will hold water until you "flip the switch." It's sort of a cross between a traditional pour over device, and a French press. Most people "wet" their coffee before starting the pour-over. This allows you to thoroughly soak the coffee before doing the pour-over.
    SWITCH Immersion Dripper 02 – Hario USA (hario-usa.com)
    If I had to give it a performance grade, would say the coffee is about 10% better with this than a traditional V60. It's not a huge difference, but it does taste a little better.
    drewskie[QUOTED] likes this.
  10. Mar 4, 2023 at 11:16 AM
    #490
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    My Technivorm has a "switch" also. I like that feature, and use it as you do.
    I turn off the machine during the bloom ........ sometimes.
  11. Mar 4, 2023 at 3:21 PM
    #491
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    That's a bit much LOL, but I like the idea. I allow my grind to 'bloom' by pouring just enough water to cover the spread, then go for broke and
    pour more to drip on down. Gawd I do love this sh*t sometimes I go to bed early so I can hurry up and wake up for a fresh brew.
    EdgemanVA[QUOTED] and drewskie like this.
  12. Mar 4, 2023 at 3:33 PM
    #492
    drewskie
    Drew
    Burbank, CA.
    This is me, coffee is literally the reason I get up in the morning
    There is some saying, I forget how it goes exactly but something along the lines of " The best part of going to sleep is knowing there is coffee on the other side"..
  13. Mar 4, 2023 at 3:43 PM
    #493
    DuffyBank
    ^ yes, three or four trips to the espresso machine each morning keeps me alive
    TacoManOne and FastEddy59 like this.
  14. Mar 4, 2023 at 3:46 PM
    #494
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    drewskie likes this.
  15. Mar 30, 2023 at 8:57 AM
    #495
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    I like to get out for a morning 3+ mile walk or run. My payoff is coffee as soon as I make it back. I don't drink any before I go to ruin the incentive to finish as quickly as possible...lol
  16. Mar 30, 2023 at 8:58 AM
    #496
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
  17. Jul 8, 2023 at 9:35 AM
    #497
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    Mrs. wanted this Breville... it auto-sizes the correct amount of grind.
    it's been a nice change from drip ... but as with most things in life, it's hard for she and I to agree on a bean that we both like
  18. Feb 16, 2024 at 8:27 PM
    #498
    2021SR5V64WD
    @jon_elc
    Just unboxed this Breville Express - no idea why the wife wanted it ... I'm happy with pour-over.
    I roast my own beans and she buys Peets.
    After a few tries we got a few good shots come through and my roasted beans were better in this machine than the peets.
    Apparently the really dark (oily) roasts interfere with the drip.
    It's a sophisticated machine for sure - trick for me was getting the proper amount of beans ( 16 grams ) and the grind level (3) just right
    in order for the pressure to behave in the proper zone.
    I do love my coffee LOL ...
    jon_elc and DavesTaco68 like this.
  19. Feb 16, 2024 at 8:35 PM
    #499
    BVSKETCVSE
    BVSKETCVSE Active Member
    2023 TRD OR
    Here is my home setup. Also used for a small business I have.
  20. Feb 16, 2024 at 8:38 PM
    #500
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I’ve got the same one, my buddy as well. Works great once you get your grind dialed in. For the price it’s a solid machine.
    2021SR5V64WD[QUOTED] likes this.
