Any Comments on TOYOS OPEN Country AT?
Discussion in 'Wheels & Tires' started by GeoTaco1, Mar 20, 2011.
  1. Mar 20, 2011 at 7:23 PM
    GeoTaco1
    GeoTaco1 [OP] Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
    I switched to the P265-70-16 Toyos O.C. AT since the OEM Rugged Trails were horrible on snow/ice.
    I am happy so far, but I am not sure what PSI to run with these? I tried 32 PSI, which is my favorite "safe" pressure, but I feel a slight fishtail? Maybe it is because we have windy days recently.
    Thanks for your replies.
  2. Dec 24, 2011 at 12:38 PM
    GeoTaco1
    Geo
    I am happy with them.
    I spent a lot of time on soft sand some rocky terrain too. Sometimes I did not air down on soft sand and they got me where I was going without getting stuck. I kept them 28 back 29 front. I got stuck only once going uphill so I aired down and I was able to back out.
    I was getting a slight wobble on the highway, but when I had my first rotation and rebalaning the wobble is not noticeable any more.
    I RATE them 8 / 10
    If it was not for the slight wobble I would have rated them 9 overall.
  3. Dec 24, 2011 at 1:19 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    I love these tires, they grip real well and are pretty good on the miles. My parents have em on their suburban and they grip so well for that truck that in parking lots they screech on turns. lol
  4. Dec 25, 2011 at 7:45 PM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    My understanding in that the toyo A/t and terra grappler are have the same exact rubber compound only difference is the a slightly different tread pattern.
  5. Dec 26, 2011 at 9:06 AM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Correct
  6. Dec 26, 2011 at 9:35 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Lundy- I was looking at the Toyos but wasnt sure which one would be better in snow.
  7. Dec 26, 2011 at 9:44 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I had them for 35,000 miles on my 2005 Tacoma... Didn't get to test them in snow, but they were fine in the desert and quiet on the highway. I don't recall the pressure that workrd best,... but I will guess it was close to 35 psi. Just try various pressures or do the chalk test.
  8. Dec 26, 2011 at 10:34 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    david- thanks for the info everything I have read is that preform almost identical to the terra grapplers. I actually just got the dynpro atf-10 ( spelling and model maybe in error) for christmas and I have snow tires for the winter ( as soon as gets cold enough to put them on) So i am set for a while.
  9. Dec 27, 2011 at 9:22 AM
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    They do well in the snow however nothing will be better than a true snow tire. I've ran terra grapplers in the winter here in the Tahoe area wit no issues but my AWD Infiniti with snow tires feels much more safer in snow and ice.
  10. Dec 27, 2011 at 9:26 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Lundy I feel like I just talked to you. Haha ya I picked up a set of blizzaks last winter for the truck. Putting the hankooks on in spring.
