Any cons to having ECT power on all the time?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by In2Ndo, Oct 9, 2016.
  1. Feb 8, 2021 at 7:14 PM
    #61
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    I never found ECT power to make a difference. The latest TSB did though. I wish the ECT power gave you V8 power but I think it just turns on the dash light for the placebo effect of extra power.
    geo8866 likes this.
  2. Feb 10, 2021 at 2:44 PM
    #62
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Nobody reads posts anymore they just post :D
    It was only a few posts back...
    cryptolime likes this.
  3. Feb 10, 2021 at 3:11 PM
    #63
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    The only con I can think of as far as having ECT on all the time maybe elevated carbon build up on the intake valves from the DI to generate the quicker response.
    Moreover, If you engage ECT and don’t feel anything, it is possible that there maybe something wrong with your vehicle, like poor quality fuel, lift. oversize tires and such.
    That said, with ECT engaged there is a notable difference you should be able to feel.
    novamchd and davidstacoma like this.
  4. Feb 10, 2021 at 4:00 PM
    #64
    Coolbeverage73
    Coolbeverage73 Well-Known Member
    Kevin
    2019 Tacoma OffRoad in Quicksand
    I have my scheduled flash for this Monday. The service guy located the TSB 00092-20. He said that he's had this flash done on several of his customers trucks so far. He said it doesn't 100% resolve it but it helps a lot.
  5. Feb 16, 2021 at 4:15 PM
    #65
    Coolbeverage73
    Kevin
    I had my reflash done. It took 1.47 hours. The power delivery is 50% smoother. The way it used to behave was that it would upshift in my estimation 2 gears to high...I would then get in a situation were I needed even a little get up and go and I would need to move through my pedal range of motion like half way...it would then downshift I am guessing 2 gear and start screaming and then after a delay start going but it was like a power on or power off switch not even remotely smooth. Basically it had the shift points originally of my prior truck which was a V8...which to me always made not sense at all for a V6 truck...I have now driven it to work twice on familiar roads so I pretty much know where it used to shift and not shift...now it is smoother because it downshift one time to get to the correct gears....It also drives better with the reflash than running the ECT button because it is smoother than that...I haven't ran it with the reflash and ECT button because honestly I think the ECT feature is kinda gay....the truck FINALLY drives a lot closer to where it should have from jump....I still cant believe how stupid this truck drove prior to this reflash and that I made it 30,000 miles like that...I haven't driven it on the highway yet but the highway driving never bothered me nearly as much as the surface streets...but i would think the highway driving would be improved also....not sure how this compares to say a Orange Virus Tune but I think I can finally live with the truck now and since the dealer put this on there should be no major issues...I just hope it holds....I have heard some say they felt like the truck reverted back to where it was before but I really don't see the logic behind that I mean a new map on the computer is a new map so I don't see it defaulting back or anything like that. The Toyota Tech who put it on told we they have put many on these trucks and on the RAV4 and he hasn't had a single complaint.
  6. Feb 28, 2021 at 10:57 PM
    #66
    TACO TM
    TACO TM Well-Known Member
    2021 Pro
    Do 2021 trucks already come with the improved shift logic provided by the TSB?
  7. Mar 1, 2021 at 5:14 AM
    #67
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Well it definitely makes a difference when not towing anything. Way worse fuel economy, and much longer shifting points. I've found when towing a lighter load, say under 1500 lbs., using ECT still isn't great either, don't need it. On the other hand my boat, and trailer are a bit over 2k lbs., I found it does tow better with the ECT engaged.
  8. Mar 1, 2021 at 5:56 AM
    #68
    MaGuyver
    MaGuyver Well-Known Member
    Savannah, Ga.
    2020 Tacoma Sport, Cement
    Tinted glass, Bed mat, Rigid light bar, Bakflip FiberMax tonneau, Bull bar, LED cabin lights, Bed lights.
    I look at it as being in ECO mode all the time and you hit the ECT button to take it out. I could see some possible gas savings, since you are not pushing harder on the pedal to get up to speed. I have to push further down on the pedal while driving when I tune the ECT off. Feels like wasting more gas.
    Daddy-Firebird- You are correct, the truck does feel sluggish.
    cryptolime, greengs and kahanabob like this.
  9. Mar 1, 2021 at 8:12 AM
    #69
    robourbon
    robourbon Member
    2017 Magnetic Gray TRD Sport
    People have made reference to the learning mode of the transmission. Does this perpetually happen or does it stop after so many miles? I recently bought a 17 with 19,000 miles so will the truck learn my driving style and not the previous owner? Should I disconnect the negative terminal for a half hour and reattach to reset it?
  10. Mar 1, 2021 at 8:18 AM
    #70
    zoo truck
    None
    Imo, something isn't right if you have to drive in the ECT mode all the time to feels its normal. I can definitely say on my truck driving in the ECT mode when not towing something substantial is not good. Engine feels like its in the wrong gears all the time needing lower rpm. Its like having the wrong axle ratio all the time. When i tried it i got nearly 5 mpg worse than i normally get.
  11. Mar 1, 2021 at 9:01 AM
    #71
    Davidbiker1
    Davidbiker1 Well-Known Member
    2021 Tacoma Nightshade
    Yeah I’m curious about it too
  12. Mar 1, 2021 at 9:08 AM
    #72
    In2Ndo
    In2Ndo [OP] Well-Known Member
    California
    MGM 2021 Tacoma TRD OR
    sadly it doesn’t look like it. Having issues with the timing chain cover leak.
    Waiting for Toyota to see what they say this week.
  13. Mar 1, 2021 at 12:23 PM
    #73
    TACO TM
    2021 Pro
  14. Mar 1, 2021 at 12:28 PM
    #74
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    ECT seemed to make it hold gears longer in the lower range. Without it (and before the TSB) it would lug in 5-6 gear.
    The TSB is the "fix". I have not used ECT since getting it done. If I am towing I just use S1-4.
    zoo truck likes this.
  15. Mar 1, 2021 at 2:07 PM
    #75
    zoo truck
    None
    Depending what your towing even S5 has been fine for me.
  16. Jun 18, 2022 at 9:20 AM
    #76
    SteveinAz
    SteveinAz Member
    2022 Tacoma SR5 3.5LV6 2WD DCSB
    I have a 2022 SR5 Auto/V6, and it seems to me the default driving mode is like "eco" mode. ECT makes the Tacoma shift more properly and predictably; at apprx 2200 rpm versus the painfully low 1200-1400 rpm with ECT off. ECT to me, is like normal mode, and I'll be driving mine with it engaged 100% of the time. Just my 2 cents.
    davidstacoma likes this.
  17. Jun 18, 2022 at 9:30 AM
    #77
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    whoever came up with the OEM tune needs a swift kick in the ass. how does it make sense to lug around in 6th gear at 35 mph? especially in a 4 cyl. truck ffs
    t2c, AxisCab, soundman98 and 2 others like this.
  18. Jun 18, 2022 at 9:41 AM
    #78
    davidstacoma
    David
    NC
    You’re a quick learner, I think you’re spot on as far as shifting goes. A friend of mine with a V6 keeps his ECT on as well. I have the 4 cylinder and always use ECT around town and rural roads. On the Interstate at 65-75 sometimes I will turn ECT off.
    SteveinAz[QUOTED] likes this.
  19. Jun 18, 2022 at 9:48 AM
    #79
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    one of my first mods on my 2016, "ECT On at Start-up" from Messo. best mod i have done.
    SteveinAz likes this.
  20. Jun 18, 2022 at 9:48 AM
    #80
    SteveinAz
    SteveinAz Member
    I have driven manual trans most of my life, and most mechanics will tell you, the worst thing you can do to an engine is "lug" it; being in too high of a gear for the rpm. The Tacoma is up-shifting at crazy low rpms in "default" driving mode. 3rd gear is really strange....it's there for about 2 seconds, and then you're in 4th.
    I don't mind pressing the ECT button at start-up every time; I did the "sport mode" button on my 5.7L Hemi Charger R/T at every start, to override the hideous "MDS" system.
    soundman98 likes this.
