Any convenient tools/methods for less spill when removing oil filter?
Discussion in '4 Cylinder' started by GotToyota, Sep 26, 2017.
  1. Sep 26, 2017 at 4:45 PM
    GotToyota
    GotToyota [OP] Well-Known Member
    Portland, OR
    Hey guys, have owned my '17 Tacoma for a few months and the first oil change will be coming up in no time. I have always preferred to do my own work, even with free services being provided by Toyota.
    I was a lube tech for over a year at a Toyota dealership and always hated doing the oil changes on the 4-cylinder engines due to the location of the oil filter and it always making a mess. The drain pan bolt doesn't cause any issues, as it's pointed at the ground.
    Are there any tools or methods you would suggest to make removing the oil filter removal less messy? I plan on doing changes in the driveway and minimal or no spillage would be preferred.
  2. Sep 26, 2017 at 4:53 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I use a cut up 1 gallon water bottle to direct the spill.
    GotToyota[OP] likes this.
  3. Sep 26, 2017 at 9:57 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    I like to use a 1 gallon ziplock bag with paper towels in the bottom. First I loosen the filter just till it turns easy-ish. Then I slide my left hand in to the filter between the back of the UCA and the rubber splash guard. Then from right below the filter I pass the bag up to the left hand and use both to slip it up and around the filter. Spin it off by right hand while holding the bag up with the left. All the oil from the filter goes in the bag and the paper towels soak it up. What drips out can be caught with some paper towels on the ground or a catch basin. Sounds complicated but it's really easy after you get the system down.
    Hardscrabble likes this.
  4. Sep 27, 2017 at 2:43 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    There's a thread in the 2nd gen (or 4cyl) section with all kinds of ideas for clean oil changes. I can't find the thread for some reason, sorry.
    The 4cyl in the 3rd gen is essentially the same so these ideas should apply to yours, for the most part.
  5. Sep 27, 2017 at 3:43 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    ^^^I like this idea, might give it a try^^^
    I use a large funnel to catch the fluid and filter during the removal. The old oil passes through the funnel and into my catch pan. I don’t have any drips or spills.
  6. Sep 29, 2017 at 4:40 AM
    iamroddy
    iamroddy Well-Known Member
    I park my truck in the garage the night before I do an oil change. This gives the oil plenty of time to settle. When I spin the filter off the next morning, it doesn't spill a drop. Just be steady and don't tilt the filter on the way out.
  7. Sep 29, 2017 at 9:22 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    i do this too, and i will add that i wouldnt attempt changing the oil on the truck if it were hot at operating temp cause you will burn the crap out of yourself on the exhaust and the oil at the same time, better to do it when the engine is cool sitting overnite like you say the oil settles in the filter then break the seal unscrewing it and let it drizzle into the catch pan until the filter is semi drained to where it wont spray on the engine, i usually get some unwanted spray but i have a ton of rags handy to mop up.
  8. Sep 29, 2017 at 4:50 PM
    BlueSTL
    BlueSTL Well-Known Member
    I spin it until it's close to leaking, then put the pan beneath it and let it leak out. I have the skids off so it doesn't pool on top of them
    TheCookieMonster likes this.
  9. Oct 7, 2017 at 7:52 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Make sure the cap is securely on a gallon milk jug then cut the bottom off. Loosen the filter just enough so that you can remove it the rest of the way with your fingers. Use one hand to hold the milk jug up over the filter and reach up around the milk jug with your other hand and spin the filter off with your fingers. It will fall into the milk jug which you can now carry away with its convenient handle. Make sure you have a rag handy so you can wipe or catch any drops that come from the filter area after you move the jug+filter out of the way.
    Hartford and TheCookieMonster like this.
  10. Jan 15, 2018 at 8:42 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I'm going to try your technique the next time. My 4X4 is a PIA. It sits high and I pretty much have to remove the skid plate to get at it without becoming a contortionist. It'll be another 4000 miles before I change it but I will let everyone know if you have discovered the proper technique.
  11. Feb 4, 2018 at 11:18 AM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    Loosen the filter to the point you can unscrew it by hand, then put a ziplock bag around it and unscrew it the rest of the way. Mess free. :thumbsup:
  12. Feb 10, 2018 at 3:26 AM
    Markcal
    Markcal Well-Known Member
    X2
    I forgot to use the ziplock bag the last time I changed my oil because I was in a rush and regretted it. Using a ziplock bag makes a messy job so much easier and wish I thought about using one from day one.
  13. Feb 11, 2018 at 3:08 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    I used a large plastic soda cup from a fast food place. I held it under the filter while unscrewing it with my other hand. The cup caught all of the oil drips, and the filter dropped right into the bottom portion of the cup. The narrow portion of the cup was the perfect size for the filter to drop in snuggly. I will be doing it this way from now on.
  14. Feb 11, 2018 at 3:28 AM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    I've always just put a regular foam plate on the bottom of the frame directly below the filter so that all the oil falls on the plate and funnels into the same basin I use to hold all the oil from the oil drain plug. Luckily I haven't had any bad spills haha, and usually works like a charm once I get the plate positioned right (which is the hardest part).
    That said the advice of using a plastic bag to catch the oil, or a big'ol plastic cup/milk jug sounds like a more safe bet haha, though it requires having to wait under the truck while the filter drips completely. Will have to give those a shot.
  15. Mar 10, 2018 at 10:03 AM
    louiemak
    louiemak Active Member
    Elias
    BOSTON, MA
    2014 TACO 2.7L L4 SR5
    AFE intake and Magnaflow cat back exhaust.
    I put a few oil absorbing sheets around the filter. I am careful when I unscrew the filter. I found out the hard way.
  16. Mar 13, 2018 at 12:30 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  17. Mar 14, 2018 at 5:26 AM
    Indy
    Indy Master of all I survey.
    I use the oil change place down the street. Totally mess free.
  18. Mar 22, 2018 at 1:29 PM
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    I laughed that this at first, then I pulled out the calculator...
    I've done around 25 changes on my 4cyl (175,000 miles & counting), and save about $40 each time (always use synthetic..). That's a grand saved, before taxes.
    So, plastic zip lock bag method for me, got it down pretty tight now!
    louiemak and CMD-KY like this.
