Any deals for torque wrenches?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DCJeeper, Jan 23, 2019.
  1. Jan 23, 2019 at 11:38 AM
    DCJeeper
    DCJeeper [OP] Well-Known Member
    Went to HF to buy torque wrenches on Monday and found that the coupon just expired:(. Any deals for inexpensive torque wrenches? Right now I only need them for oil change and tire rotation.
  2. Jan 23, 2019 at 11:52 AM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    Harbor freight has a sale almost every other weekend. They'll be back soon enough. Just let it be known they are not super accurate (as one should expect with harbor freight). All ours at work failed calibration, some over torqued others under, some did both on opposite ends of the spectrum. Not significantly enough to where i would worry about a bolt coming loose or stripping on things i would normally torque by hand to "that should be good" and definitely better than counting ugga duggas with an impact.
    cipherbreaker likes this.
  3. Jan 23, 2019 at 11:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I agree and had a pro check the calibration of mine in the past. Also, if you look at the torque adapters out these days, they are invaluable: I have a similar 1/2in drive one, and it reads down to 5N-m. It is also great for checking the calibration of torque wrenches.
    Just in case, always store a clicker type torque wrench with the dial completely backed off.
    Garyji, BigWhiteTRD and Vbpiper like this.
  4. Jan 23, 2019 at 11:54 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
  5. Jan 23, 2019 at 11:57 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Just curious, why would you buy the very cheapest torque wrench if you have any interest in how tight the bolt/nut is? Spend a bit more and get one that is actually repeatably accurate. Don't get me wrong, HF has some great tools, but this is not one of them (for what it is intended for).
  6. Jan 23, 2019 at 11:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not to start an arguement, but I've had my HF 1/2in drive for over 20yrs installing everything from lubricated SS fasteners into cast AL threads to lug nuts to swaged crankshaft / sprocket nuts. Never an issue for me. I'm just one data point though.
    It is very true that I would never use it professionally or in a shop environment mainly because I would not trust that it would take the abuse of others using it. For that, a split beam is the better choice. For home, I never had a single doubt when caring for it.
  7. Jan 23, 2019 at 12:02 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
  8. Jan 23, 2019 at 12:13 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    Who are you, the referee?
    shane100700 likes this.
  9. Jan 23, 2019 at 12:16 PM
    cipherbreaker
    cipherbreaker Well-Known Member
    Tekton has been solid so far. I've had it for a few years.
    CusterFan and Boosted_Carrera like this.
  10. Jan 23, 2019 at 12:18 PM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    There is no way I would trust a tool from Harbor Freight to be calibrated properly. The Tekton torque wrenches are very reasonably priced and a bit more trustworthy.
    CusterFan, shane100700 and Vitalzone like this.
  11. Jan 23, 2019 at 12:21 PM
    Mad Mark
    Mad Mark Well-Known Member
    18 TRD 4x4 off-road
    The 3/8’s cheap hf torque wrench kinda sucks. It doesn’t lock in and the handle will spin to a different torque if you aren’t paying attention. And it only goes to like 60ft lbs. I love HF stuff too btw.
  12. Jan 23, 2019 at 12:24 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Check out Gear Wrench they've never done me wrong. I'm never buying harbor freight again. I've had one of their sockets explode with just a wrench on it
  13. Jan 23, 2019 at 12:25 PM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Get a 1/2" drive and a 3/8" adaptor or visa versa. As others have mentioned, don't buy cheap. Every year or two, have it professionally calibrated. That is very important, even for a new one before you use it for the first time, especially if it is junk cheap!
  14. Jan 23, 2019 at 1:09 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My 3/8" drive is inch pounds and the 1/2" is ft lbs
    Vbpiper and tonered like this.
  15. Jan 23, 2019 at 1:30 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  16. Jan 23, 2019 at 3:33 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I really like that load cell unit from harbor freight, but seriously are people torquing bolts that often/careful...
    On the 3 homebuilt aircraft (including rebuilding 2 engines for them), probably only torqued connecting rod bolts, cylinder hold down bolts, prop and wing attach bolts.
    People torque like most of the bolts?
    tonered[QUOTED] likes this.
  17. Jan 23, 2019 at 3:45 PM
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    All you need is the 3/8. That is what i have and that is all i needed. Make sure you follow the instructions and set it back to zero when finished using it so that the spring does not get messed up.
  18. Jan 23, 2019 at 3:48 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Willing to bet the Tekton and HF wrenches come out of the same factory over seas.
    That snap on is old af and beat to hell. Hard pass.
    shane100700 and tonered like this.
  19. Jan 23, 2019 at 3:58 PM
    LeeVanChief
    LeeVanChief Well-Known Member
    2018 OR 6Speeeed Taco
    Hf hand tools have nearly killed me on more than one occassion .
    shane100700 and beergeek like this.
  20. Jan 23, 2019 at 4:29 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I do for the reason that my arm has no idea what gutentite is. More like hamfisted gorilla.
    It also gives me a lot of comfort on my bike.
    The original reason for the HF wrench purchase was to properly torque lug nuts to true notoriously thin rotors on my Dodge. It caused a true mech with a "calibrated arm" a bit of red face when it fixed the problem on his Accord also.
    BigWhiteTRD[QUOTED] likes this.
