Any definitive cargo weight info?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by esses, Jan 3, 2018.
  1. Jan 3, 2018 at 8:13 AM
    esses
    esses [OP] Well-Known Member
    2017 TRD Sport Double Cab, Long Bed, 4WD
    Toddler Car Seat and some cardboard boxes in the bed.
    This may seem like a duplicate thread but I can’t find anything definitive. :(
    im trying to figure out if I can take 730 kg (1600 lbs) of boxes in the long bed from la to Phoenix. (About 300 miles of highway including a few mountain climbs)
    The internet / search seems to say about 1600 pounds. The door jamb says 950 lbs.
    And there’s people on here that say all kinds of “more”
    I have the tow package if it helps. Though I’m not towing here.
    How much weight have you put in the tacoma bed?
  2. Jan 3, 2018 at 8:22 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I hauled 1100lbs of sand in my 2nd gen on multiple occasions and the truck did haul it, I would not do it again for more than a few miles. Every bump I hit was not a fun at all, the truck was not on the bump stops but the rear end was sitting pretty low.
    Bolsillos5624 likes this.
  3. Jan 3, 2018 at 8:26 AM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    I think you'd be crazy to try that -- it's well over the truck's rated capacity. It'd strain the heck out of so many components, be a terrible ride, and would be irresponsibly unsafe, too -- imagine having to slam on the brakes in an emergency coming down a hill or make a quick maneuver to avoid something... you'd be lucky if you didn't wreck or kill someone else. Rent a trailer and haul the load that way.
  4. Jan 3, 2018 at 8:28 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Why not just rent a uhaul and call it good? You would be bottoming out the suspension probably causing permanent damage.
  5. Jan 3, 2018 at 8:32 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    1600lbs does seem excessive. I was able to leave 1000 square feet of tile and cement board in the bed over night then haul it 20 minutes away the next day without an issue. But 1600 doesnt sound like anything I would be comfortable with, at least not directly in the bed.
    esses[OP] likes this.
  6. Jan 3, 2018 at 8:33 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    The rated GVWR for my Tacoma (2008, Access Cab, 4WD, stick) is 5,350 lb. The curb weight given by Toyota is 3,965 lb. So the capacity is 1,385 lb. Your truck will be rated similarly, I assume the 950 lb that you refer. Bear in mind this is before even putting fuel or the driver is added. The real payload for my truck was round about 1,000 lb before I did anything else to it (camper shell, armor, extra battery, I really only have a couple hundred lb of cargo I can add). So you'll be fairly far over the capacity adding 1,600 lbs of cargo, which is really more like 2,000 lbs when you factor in everything (fuel, passengers, tools, etc.).
    esses[OP], tonered and xxTacocaTxx like this.
  7. Jan 3, 2018 at 9:02 AM
    esses
    Well this seems pretty unanimous. Even those who claim to have exceeded it did so or short/local trips. Thanks all. Guess I'm renting a trailer.
  8. Jan 3, 2018 at 9:09 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    trailer rentals are like $40 a day from U-Haul. Totally worth it.
  9. Jan 3, 2018 at 9:19 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Only if one way. Otherwise they can be 10x that. Done it.
    I have hauled 1600 lbs of tile in my bed without any issues... for about 10 miles. I think for the longer haul I would use a trailer. I have also pulled 1.5 yards of stone for 25 miles, which weighs about 3000lb + trailer. Truck didnt like that much at all.
  10. Jan 3, 2018 at 9:20 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yep. Rent a trailer. I have hauled a half ton (on top of my weight and fuel and stuff) and, while heavy, did fine. Wouldn't haul more than that though for any real distance.
    Skydvrr likes this.
  11. Jan 3, 2018 at 9:24 AM
    Miller1103
    Miller1103 Well-Known Member
    2017 trd or dc quickaand
    I would get a trailer for sure. I have had just over 1200 lbs of sheet rock in my truck. This was with Dakar medium duty leafs and it was still to much imo.
  12. Jan 3, 2018 at 9:29 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    Your factory payload rating is 950lbs
    A/Cab V6 4x4 = 1,150lbs
    A/Cab 4cyl 4x4 = 1,300lbs
    A/Cab 4cyl 4x2 = 1,500lbs
    These are all for automatics.
    Tacoma has some pretty low payload ratings. A ridgeline for example can haul close to 1,600lbs in the AWD Crew Cab.
  13. Jan 3, 2018 at 10:36 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    2017 brochure says your particular truck is 1,120 lbs.
    Tow package actually reduces that.
  14. Jan 3, 2018 at 9:58 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Ditto, rent a uhaul.
    The GVWR for all variants is 5600 pounds. Often times the curb weight listed is with an empty gas tank and no options. An average guy and his V6 4x4 taco is probably 4900+/- pounds.
    I've hauled 2/3 yard of gravel multiple times with my '98. But it was for a few miles at a time and was within .5 inch of the bump stops. Definitely wouldn't want to do long highway trips.
  15. Jan 4, 2018 at 6:30 PM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Anything over 1k and you’ll be hitting bumpstops every bump....
    hr206 likes this.
  16. Jan 4, 2018 at 7:52 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    In preparation for the weight of a canopy and filling the bed with gear, I wanted to know how much the rear end of my truck would sag with weight in/on the bed.
    I placed one large ice chest in the bed today, filled it with water and calulated the weight. I continued to add several 5 gallon buckets of water and also used 5 gallons of paint and my stock take-off Goodyear tires for at least 590 pounds estimated. I placed most of the weight over the axle and towards the rear of bed.
    This dropped the bed down a bit over 1 1/2 inches from 37 1/8 to 35 1/2 inch from floor to wheel opening on the left side.
    Front left was at just over 36 inches at start.
    Maybe an add-a-leaf is in order for the next project.
    So, for every 200 pounds added, there was about 1/2 inch of drop to the bed for this first approximate 600 pounds.
    penguins and hr206 like this.
  17. May 6, 2021 at 6:22 PM
    thirdhuey
    thirdhuey New Member
    2018 Tacoma TRD off road, just drove 100+ miles in Maine with 30 packs of shingles in the bed (roughly 1600-1800 pounds). Drive smart and you’ll be fine.
  18. May 7, 2021 at 12:49 AM
    waltuo
    waltuo Well-Known Member
    Toyotas
    o_O
  19. May 7, 2021 at 1:53 AM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Toyota defined the truck's payload they put it on a sticker in your door jamb. If it says 950lbs that seems pretty definitive.
    Can you put more in and have it work out? Many have and it has but anything over the trucks rated capacity and you are on your own. rent a uhaul trailer and you won't have to question it.
