Any Difference between Tacoma Beast Headlights vs Ebay/Amazon ones?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jacked Burton, Aug 3, 2019.
  1. Aug 3, 2019 at 4:36 PM
    Jacked Burton
    Jacked Burton [OP] Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    Looks like Tacoma Beast only Has black ones left when I was gonna go with chrome since the Chrome/Smoked CCFLs matched so well with the oem chrome left on my grill.
    Is there any quality difference or are you basically paying for the customer service?
    $400 vs $240
    I'm not cheap,just BAF,but willing to pay the difference if there is a quality difference IE projector quality or Housing doesn't melt with after market lights.
    https://tacomabeast.com/products/05...light-bar-drl-version-2?variant=7152326606878
    vs
    https://www.amazon.com/dp/B07CMB2FL...olid=38SS1T1UZFZVS&psc=1&ref_=lv_ov_lig_dp_it
  2. Aug 3, 2019 at 4:54 PM
    TacoTuesday1
    FL
    I thought about upgrading from stock chrome, to blacked out TRD ones. Both OEM. But for the same headlight that just has some internal trim that changes to black, it doesn't seem worth the price.
    Is it worth considering another option; modifying the existing headlight somehow?
    I don't know if it matters to have separate lights within the housing. Such as a main beam, and high beam separate. To act as a flasher and high beam when needed.
    Because in the case of projectors, they take seconds to warm up and change color. So they don't get used for high beams. Halogens do, because they respond quicker. However, on some cars, their xenons are "bi-xenon" which means that when running/already on at night, a cutoff shield flips down via motor, to allow more light to escape from it. Which makes the xenon be sort of a "helper" to the high beam.
    The difference lies within LED's, which are known to have a very fast response time. If using LED's, those can probably act in any capacity.
    For example, the Acura TLX with it's jewel eye LED headlights. Somehow, that car manages to use those "jewels" to act as both low beam and high beam, or are even able to be flashed from an Off position.
    I heard in recent years, Toyota was one of the first to start using an LED projector. Maybe called "Koito" brand or something. I wonder if that can be used.
    Folks on the lighting specialist forum HIDplanet probably know more about this stuff.
    As opposed to Audi's that used not Koito but Bosch/AL, which I think was a merge of the companies Bosch and AL (Automotive Lighting) or something.
  3. Aug 3, 2019 at 5:15 PM
    Jacked Burton
    ^^^ Not sure if That was a Troll or Thread Jack...
    Boyk1182 likes this.
  4. Aug 3, 2019 at 5:20 PM
    TacoTuesday1
    FL
    Are the headlights in original post known good performers? I'm just saying man.
    Last time I had a style that looked just like that on a different car, and the lighting was pretty bad.
  5. Aug 3, 2019 at 5:30 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    There's nothing special about the ones TB sells. I believe they are Spyder headlights so you are likely will find them cheaper elsewhere. They look good but output nothing special since they are halogens.
    Jacked Burton[OP] likes this.
  6. Aug 3, 2019 at 5:33 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    They’re rebranded, from the same factory.
  7. Aug 3, 2019 at 5:33 PM
    Jacked Burton
    This is what I assumed.
    I think the retrofit source has a better projector to put in them that pretty plug and play.
  8. Aug 3, 2019 at 5:33 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Dont buy from tb
  9. Aug 3, 2019 at 5:36 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
  10. Aug 3, 2019 at 5:49 PM
    Dalegribble02
    DirtJumper14 likes this.
  11. Aug 3, 2019 at 9:40 PM
    Randy Tacoma
    Randy Tacoma New Member
    2010 Trd off road
    I have the Tacoma beast headlights so far I like them no issue you can use exclusive for 100$ off your order
  12. Aug 3, 2019 at 9:45 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Ebay will have better customer service than TacomaBeast.
    tetten, Yota_Ivan and DirtJumper14 like this.
  13. Aug 3, 2019 at 9:49 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    You can get the same lights on ebay/Amazon for much, much cheaper. You won't have to jump through hoops for warranty or even a response like you will with TB
  14. Aug 3, 2019 at 9:57 PM
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    I installed these Spyder Sequential Headlights today. My thoughts are on par with the rest. Really cool “looking” Headlights. I think OEM DRL is brighter than these. Halogens is what it is. Not bad, but not good either. Decent and I can live with it for now. I did see a video of someone switching out the bulb to a cheap LED. Looked way better but he did warn that it would void the warranty. Overall, I like them. I’ll give it a 7 of 10 rating. The Retrofitsource headlights are the real deal. If I could afford them I would be going that route. For now this will suffice.
    Randy Tacoma likes this.
  15. Aug 4, 2019 at 5:55 AM
    Timinatorx92
    Timinatorx92 Well-Known Member
    2006 Black Tacoma AC TRD Offroad
    3" toytec lift Method 16x8 Grid Coopers at3 xlt 295/75/16
    i emailed TB before with the same questions.. they never gave me a straight answer.. so i would assume that it's the same headlight you can get from Amazon or ebay.
  16. Aug 16, 2019 at 6:19 PM
    rocklobster2008
    rocklobster2008 Well-Known Member
    Jayson
    Fort Worth, TX
    2008 Red Tacoma TRD Off Road
    Brute Force Fab front bumper Dobinsons Snorkel 35" Nittos Bilstein 5100s ICON leaf springs RSI SmartCap Bed Replacement Diode Dynamics lighting Custom built morimoto headlights RCI full skid
    Anyone cracked either of these headlights (Amazon or TB) open to see how the projector is mounted or what projectors they use? Thought about getting these instead of buying the regular depo and doing another projector mod on those. I did a set of projectors in some depos and they served me great but I'm ready for an upgrade to the morimoto mled and really liked the look of these Amazon or TB one .
  17. Aug 16, 2019 at 6:53 PM
    keisersoze
    keisersoze Well-Known Member
    I have the ebay ones and they look identical to the TB ones.
  18. Aug 17, 2019 at 7:41 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Has anyone gotten any aftermarket lights that don't end up leaking?
  19. Aug 17, 2019 at 9:56 AM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    there have been a few recent reports of tacomabeast lights leaking, and many complaints about their horrible customer service. i’d guess it’s the same as the ebay set.
    from what i’ve read, depos have the least complaints, but ALL aftermarket lights are more prone to leak more than oem. most aftermarket lights aren’t sealed well at all. if i didn’t live in az and cared about leaks, i’d bake my depos and reseal with morimoto. this is the correct stuff to use on lights. not silicone!!!
    i just got a front and rear set of depos off ebay for $233. the literature that came with them basically said leaks are normal and to expect them. lol.
    RetroRubber OEM Grade Butyl Headlight Sealant, Black https://www.amazon.com/dp/B01N5PM29J/ref=cm_sw_r_cp_api_i_ffdwDbF20CYK9
  20. Aug 17, 2019 at 1:37 PM
    rocklobster2008
    Jayson
    Fort Worth, TX
    I really enjoy my depo! Resealed them when I did my projector retrofit and zero leaks!
