Any difference in auto vs manual 4.0 engines?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justinsimpson773, Feb 27, 2023.
  1. Feb 27, 2023 at 4:31 PM
    justinsimpson773
    justinsimpson773 [OP] Member
    Justin
    2008 tacoma 4wd 4.0l 6spd black Access cab
    Bilstein 5100 lift, old man emu springs. New frame from yota (yayyy), 17' alloy wheels with 33s mud terrains. Spidertraxx 1.25 spacers on all 4. 85k miles and going up.
    I blew up my 08 tacoma 4.0 engine. Truck is a MT. Oil pump failure, very similar to a thread I read a while back on here. Heard the screeching sound like my belt was going to explode.....turned out that was my oil pump shredding itself :/
    Anyway, I found a motor from an 05 automatic. While I am 99% positive the 4.0 is the same regardless of the transmission, I actually could not find any information confirming this. I am positive it is on TW, I just haven't found it.
    So that being said, will the donor 05 4.0 that came stock with an AT fit my 08 with a manual transmission?
    Again, I apologize if this has been covered already, and thank you in advance!
    PS. Don't worry, I am replacing the head gasket as soon as I get the motor, as well as the timing chain/guides and such. My previous 05 tacoma had a blown head gasket at 181k, and I know it is a common issue.
  2. Feb 27, 2023 at 4:36 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yes you’ll just need to swap your flywheel, clutch and pressure plate over
    Dm93 likes this.
  3. Feb 27, 2023 at 5:11 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes 05-11 Tacoma 4.0s are all the same aside from the headgasket being updated mid 06, only the one in the X-Runner I believe had a different oil pan but Auto and Manual are the same engine just a different flywheel.
    TnShooter and BassAckwards like this.
  4. Feb 27, 2023 at 5:19 PM
    justinsimpson773
    Justin
    Thank you @BassAckwards and @Dm93 !!! I am picking up the engine tomorrow, so excited to get my taco back on the road! it has been over a year, so I am very excited to get it going again
